Question phpbb3 to Kunena
If you have twice the same username with 2 IDs or opposite, that'd be tricky, indeed...
Thank you
How many users do you have to migrate ?
Did you checked if the posts where linked to the right author or not ?
Thank you for your support. The users to migrate are around 100. I don't know how to make the check you asked but maybe you are referring to check after the migration? (in the kunena forum just imported?).
I made the same kind of migration, somehow 100 users and it worked perfetly with my mentionned method... Sorry to say that, but I don't understand why it doesn't work.
I'm tring to repeat the entire process step by step however there is a point in the described process that I don't understane very well. The go.php script imported all the forum categories and post into my kunena db and also created all the users (my starting Joomla have only the administrator user) into Kunena and Joomla. At the end of this operation I have the same users between Joomla and Kunena syncronized with the same ids thta why I need to execute the first query? (the query return me the error). From what I understand from the description this query allow to syncronize Kunena users with Joomla users but in my case it seem they are already syncronized (same id in Joomla and Kunena) that what is the purpose of this query?
UPDATE `jos_fb_users`,`test_mig_users_id`
SET `jos_fb_users`.`userid`= `test_mig_users_id`.`final_jos_id`
WHERE `jos_fb_users`.`userid`=`test_mig_users_id`.`former_phpbb3_id`;
I found only another problem. In some of the post I'm importing there are some japanese message (written with kanji) and into Kunena I see only some "????" instead of kanji. I checked the tables charset and I found that kunena table have sweedish charset instead of unicode. I searched into the forum and I found some other people have the same problem but I didn't understand very well what is the way to fix it, I must to chaneg manually the charset associated to any table field manually or there is some other way to fix it?
Thank you again for the friendly support.
