- Thank you received: 2
Question phpbb3 to Kunena
my know how in PHP is not very good so I really need your help.
For an expert in PHP development must this very easy.
in the PDF-File in the attachment I wrote what I need to convert the Attachments from phpbb3 to Kunena.
Gruß Mark
Pickup-Wohnkabinen-Forum Kunena 4.0.7
Chevy-Forum Kunena 3.0.8
I'm trying to convert (with go.php) but conversion stops here:
Nothing happeded after "Populating Messages_Text Table..."??? What should I do ?
Resolved: It was about max_execution_time setting in php.ini.
I did find a way round the password issue. It's a long way round but it did work.
I first installed a test joomla with Jfusion linking into the phpbb3. Synced all the users using jfusion. Then on a fresh joomla install with kunena/fireboard (seperate DB from the test install I followed the go.php instructions in the phpbb3>>fireboard convertor. Once all the users/posts were transferred across I then used a simple php script to copy the passwords for each user from the jfusion/joomla DB to the relevant users in joomla/kunena DB (needed as the user ID's will not be the same.
The password copying script is available in this thread by the person who kindly made it for me
www.cableforum.co.uk/board/19/33659901-php-script.html
Yep it's a long way round but at least the jfusion usersync converts all of the passwords and as long as your secret key is the same in your joomla/jfusion and joomla/kunena installs the passwords will work.
Now what I would love is for the convertor to also copy across the users PM's
:kiss:
I check and tried script for passwords and i get:
You said that
Could you post modified script here on PM it to me , please.Yep, just added $db1_result = "";
And one more question... Which one is the database (on the password script) which have users syncronized with JFusion? Is it db1 or db2?
Regards,
Juraus
www.hugzzz.com/passswap.rar
Here's a RAR file with the new code in place, I've marked the DB old and new and please remember that for this to work the Secret Key has to be the same as the old Joomla as it's salted into the password hashes. Please test this out on copies of the DB's first to make sure it works
Thanks!!! Just to be sure: is the olddatabase the database which have users syncronized with JFusion?
-Juraus
The newdatabase should be the new joomla DB with the migrated kunena data, the old database is the joomla/jfusion/phpbb3 database. So it's copying the passwords from the old to the new..
Please, please, please try it first on copies of the db's
