Question phpbb3 to Kunena
Indeed, after current (and only one available) migration option (through fireboard) only problem is the one of users mapping.
It is obvious that none will have the same configuration among J! users as they don't all use a bridge, or did map their users between PHPBB and J!.
I would think of a tough solution which would be to ask the admin, preparing the migration, to map himself the users, like saying "PHPBB User ID 54 is J! user 32" for instance. Not very handy nor automatic, but it would do the trick. After, for a community of more than 100 people, it would begin to be very very hard.
Maybe contacting Jfusion creators could help, in order to understand their mapping method, no ?
- wingnut144
- Senior Member
Or is there still another issue?
Point is that if Joe's PHPBB3 user has ID 43, once you will migrate, Kunena will link his posts to J! user ID 43 which may not be Joe but Peter (for instance). Most of the time, and there is nothing which can assess the opposite, users's ID won't be the same, due to registrations delays, DB modifications, etc...
So if you are SURE that PHPBB3 and J! users ID are the SAME, then you can use the only available now solution migrating from PHPBB3 to FB then to Kunena.
Else, please bear with us and help us praying Matias for a component release. ^^
I have a couple of questions. I am starting fresh with a new Joomla 1.5 site which has no users yet (apart from admin). But I have a phpbb3 forum which has over 300 users. I want to change over to Kunena so that I can use Alpha User Points and other Kunena compatible things. My first question is:
Would it be fairly simple for me to change over, seeing as I currently have no users in Joomla 1.5?
I am guessing the conflict stuff that is referred to in the last few posts wouldn't apply. If so, my second question is:
What is the EASIEST way for me to migrate from phpbb3 to Kunena? (should I do the step by step method, or wait for the migration tool?)
Any help with this would be greatly appreciated.
If there's no other user logged on J! but you, step by step method should be fine... but you should first try on a separate database. If not working, you can still try Jfusion to sync users among forum-site.
Else... there's still some place here to pray Matias ^^.
One problem is I can't seem to get ANY login to work! I tried clicking on the "sync users" button, but when I do I see no activity whatsoever. It just gives a generic: "Sync FireBoard user table with Joomla! user table" message
Am I doing something wrong?
I even upgraded my own previous phpbb3 username to a super admin status, but I couldn't log into back end, because it said that username and password did not match, even though I did type in the right password. If I go to user manager, I can set a new password for myself and then i can log in, but i can't log in without doing that.
My users will be very annoyed at having to reset their passwords. Is there any solution for this?
www.kunena.com/forum/101-solved-or-prior...a-step-by-step#12633
I really, really need this. I have 1100 users to move from phpbb3 to Joomla and Kunena.
We could also think that users may be able to upload them back, cleaning up old inactive users data, no ?
Matias > Did you succeed to step ahead regarding user sync ?
Edit :
I succesfully corrected the user sync problem after migration with a SQL update of Kunena's tables.
1- I exported the PHPBB3_users and jos_users table to excel, mapped new ids, removed bots and created a CSV file with phpbb3_former_id and jos_final_id that I imported via PHPMyadmin.
2- Second step is to update the kunena's user table with new ids :
One issue remain is to have each user post count with REAL post count... only found one hack to do it ... Any implementation foreseen ?
One question more : my current migration is only for tests purpose. Can I delete all jos_fb tables and Kunena before final migration ? Would that make any issue to delete the DB tables ? Will Kunena/Fireboard reinstall them itself ?
