Question phpbb3 to Kunena
- wingnut144
- Senior Member
If its the full deal, do you have a step by step guide that you can post? I'd be curious to see if I can get my phpbb3 users into Kunena......
Krycek wrote:
Edit :
I succesfully corrected the user sync problem after migration with a SQL update of Kunena's tables.
1- I exported the PHPBB3_users and jos_users table to excel, mapped new ids, removed bots and created a CSV file with phpbb3_former_id and jos_final_id that I imported via PHPMyadmin.
2- Second step is to update the kunena's user table with new ids :
One issue remain is to have each user post count with REAL post count... only found one hack to do it ... Any implementation foreseen ?
One question more : my current migration is only for tests purpose. Can I delete all jos_fb tables and Kunena before final migration ? Would that make any issue to delete the DB tables ? Will Kunena/Fireboard reinstall them itself ?[/quote]
Upper proposal is here to solve that user sync, awaiting Matias' component.
Finally I have ALL posts brought to Kunena and ALL users synced with J!.
Status:
I haven't had too much time to play with Kunena Importer lately. So not much has happened with it except for few small bug fixes.
I've also played with JFusion and it seems to have just what I've been looking for: it saves userid mapping between Joomla and all external components. This makes phpBB3 import a lot of easier -- at least if you're using JFusion bridge.
I will now try to get import complete enough that it is possible to test it..
- wingnut144
- Senior Member
I appreciate all your hard work on this! Just curious, do you think it will be a week before we know if it works? 2 weeks? Not trying to pressure ya
Steve
