Question phpbb3 to Kunena
This would then be related to some other Kunena post that you'd have to create.
Glad that your migration worked anyway !
Unfortunately this last problem of japanese characters not imported well continue to be a seirous problem for me. I cheched the kunena/fireboard db tables, all the table have a charset set to sweedish, I changed manually all the attributes to unicode before import the data but after the import only some fields (like category name) has been imported correctly, all the other japanese words was showed as ????? into Kunena. Do you suggest to open a new discussion more specific to this problem?
I have managed to sync all the userid between fb and phpbb. Posts display correctly etc but I am having difficulty logging in.
I have enabled the password plugin found on www.kunena.com/forum?func=view&catid=101&id=12556 and this too does not work.
Does anyone have any suggestions/fixes that may help?
I was thinking perhaps someone may have written a script that resets everyone's password and emails them the new one?
Glad for you that it worked !
I have vbulletin 3.84 which I can easily convert to phpbb3.06 and have just done that successfully as a test.
I think I read somewhere else in these forums that the next version of kunena will have built in converters for phpbb3. Is that correct? :blink:
I dont think I have enough techie experience to perform the detailed conversion instructions that others have tried to undertake
I have a good phpBB3 Database backup (my server screwed things up), and now I want to build a Joomla 1.5 site with a forum.
After researching, I see that it's better to have a native joomla forum, than phpBB with a bridge or something like that, because I need things simple.
Npw I'm trying Kunena in a testing server, following the migration steps explained here , but when I try to open the converter in browser (In a browser, navigate to yoursite.com/converter/go.php.) it automatically goes to a error page. I've checked the servers MySQL info, and all seems ok. Could it be a server limitation?
If you want to try here's the link:
portalfpg.000space.com/converter/go.php
Any help?
