- Forum
- Archive
- Kunena 1.5
- K 1.5 Installation, Upgrade and Migration
- K 1.5 Installation, Upgrade and Migration Archive
- phpbb3 to Kunena
Blue Eagle 5 v1.6.2 has been Released for Kunena 5.2 (20 Jan 2021)
The Kunena team has announce the arrival of Kunena template Blue Eagle 5 v1.6.2 which is now available for download. This version addresses most of the issues that were discovered in development.
REQUIREMENTS
Question phpbb3 to Kunena
I did it! As my problem seemed to be some limitations from a free web host, I tried in my pc, installing XAMPP.
So now I've migrated phpBB to Kunena 1.5.8.
Now the thing is that the users can't login, it says that the username or password wrong. I've checked the users in backpanel, and it seems that they are all inactive. What can I do? Or could this be the passwords that were cleaned?
Don't you have any test account to check by yourself ?
Then check wether accounts are enabled. If not, have a look to the DB and check for discrepancies with your account (that should work).
Last, you can still force new password registration for all accounts.
Even though, that is very strange...
Sure I have some accounts for testings purpose, beside of my own. That's why I said that the users can't login. I'm still in development enviroment, not online.
I'll compare the tables from the database for this, and post the results here.
It worked for me. The only problem I had was with the avatars and images, but that's explained in the guide, and some passwords doesn't work. Don't know why, but it's not bad since we can't reset the passwords if needed.
For my experience, use it in your pc (xampp, lampp, etc), then upload to the server once it's done...
Good luck with that
I first installed a test joomla with Jfusion linking into the phpbb3. Synced all the users using jfusion. Then on a fresh joomla install with kunena/fireboard (seperate DB from the test install I followed the go.php instructions in the phpbb3>>fireboard convertor. Once all the users/posts were transferred across I then used a simple php script to copy the passwords for each user from the jfusion/joomla DB to the relevant users in joomla/kunena DB (needed as the user ID's will not be the same.
The password copying script is available in this thread by the person who kindly made it for me
www.cableforum.co.uk/board/19/33659901-php-script.html
Yep it's a long way round but at least the jfusion usersync converts all of the passwords and as long as your secret key is the same in your joomla/jfusion and joomla/kunena installs the passwords will work.
Now what I would love is for the convertor to also copy across the users PM's
- michelgofman
- - after checking out the Importer from SVN TRUNK and building the zip with the shell script provided
- - the Joomla install works
- - but when I click on the component I get
Fatal error: Call to a member function getName() on a non-object in /var/www/xxxxx/libraries/joomla/application/component/view.php on line 449
I am running the last Joomla with the last Kunena on a local Ubuntu Karmic workstation / server
Mike
This is my biggest problem!!!
I need it very quickly, so can "anyone" make a script? I think Kunena 2.0 will take some time, when I read the blog, not until end of year 2010? rather 2011?
My Forum is big, relative
Gruß Mark
Pickup-Wohnkabinen-Forum Kunena 4.0.7
Chevy-Forum Kunena 3.0.8
Forum Access
- Not Allowed: to create new topic.
- Not Allowed: to reply.
- Not Allowed: to edit your message.
- Forum
- Archive
- Kunena 1.5
- phpbb3 to Kunena
