Kunena 6.0.8 Released (17 Jan 2023)
The Kunena team has announce the arrival of Kunena 6.0.8 [K 6.0.8] which is now available for download as a native Joomla extension for J! 4.2.x. This version addresses most of the issues that were discovered in K 6.0 and issues discovered during the development stages of K 6.0.
Merged K 2.0 general menu issues
- henrik1782
- Jiminimonka
- Elite Member
- YBAS!
Thanks for your help!
Oliver
The answer is here
Problem with update 2.0.3
Instalaltion smoothly.
But the forum does not appear ...
Joomla 2.5.8
Kunena 2.0.3 and modules and Pugin update ...
Can you help me
thank you
I think you will find your answer here, in this topic.bking1300 wrote: Installed smoothly but the forum does not appear.
Better yet when I use that is noted on the video it destroys my position kunena_menu menu. elel for no longer exists. Although entenud module is not recreated.
And when I use the main menu is recreated on the forum home page forum does not spawns. Under 1.7.2 and everything works perfectly as before.
Since version 2 is the Beresina ... LA update created everything right but not component ... I just rebuilt 50 times
Do you have an idea ...
I think if Kunena problems, and its advantage of being free this advantage is now a ruin for me time and patience.
I switch to something else because there are components that have a true support service and especially that work better ... ezet this mêm but are paying e is more economic production.
It is no longer what it was. Viewing it moves the question in another forum as this is not the same, are plsu 15 days to respond.
I actually created a confused and débruillle you with ...
In fact it is not confused Kunena Forum is forum ..
