Sticky K 2.0 general menu issues
A menu item is created in your home/default menu; the menu item to lead people to your forum is inactive until you publish it. This is shown about 2 minutes into the video.
- François59
- Junior Member
- François59
- Junior Member
I will try later to migrate to the version 2.0.1
Before upgrading to 2.0.1 when using 1.7.2 my menu item for my forums was mysite.com/forums , however now I have to use mysite.com/forums/index or as its default it is mysite.com/forums/topics/mode-replies . (note I modified the Kunena Menu 'Forum' item to 'Forums'
I have in my main menu an alias pointing to the 'index' menu item in the Kunena menu. If I point it to the 'Forums' menu item (in the Kunena menu) the url is mysite.com/forums/topics/mode-replies , which again is not what I want, I want it to be the same as it was for 1.7.2. If I use a direct link to the Forum Home page instead of an alias and change that item to be an alias of 'forums' I can get it to work using the url of mysite.com/forums but the kunen menu does not display again when viewing the forum.
I also tried a 301 redirect from mysite.com/forums/index to mysite.com/forums but what that does is revert it back to mysite.com/forums/topics/mode-replies instead of just leaving it as mysite.com/forums .
This is driving me nuts, does anyone know how I can get it to revert back and just use mysite.com/forums as the forums default home.
