Sticky K 2.0 general menu issues
14 years 3 months ago #131467 by gwmbox
Replied by gwmbox on topic Missing Kunena Menu
*sigh*
14 years 3 months ago - 14 years 3 months ago #131887 by mlines
The tabs from the top of the forum (INDEX, MY TOPICS, RECENT TOPICS etc...) disappeared after upgrading to 2.0.1
Where should I start looking..
www.bigjimny.com/index.php/forum-mainmenu/category/list
Ok - I SHould have looked through the common issues, menu disappearing is listed!
Last edit: 14 years 3 months ago by mlines.
14 years 2 months ago #133250 by dov.lachman
Hello all
I will thank for answer, where is the file that i can change the words in the tabs?
14 years 2 months ago - 14 years 2 months ago #133251 by sozzled
G'day, dov.lachman, and welcome to Kunena.
Your question is very similar to " How do I edit, hide, disable or translate menu items in Kunena (e.g. rules, help, search) " - a question we've received over a hundred times.
The FAQs page also has information on this subject.
There is no file to change. The menu you see in K 2.0 is not very different from how things were done in K 1.7. The Kunena menu is a Joomla menu and you edit the items just like you would edit the menu items of any other menu.
Last edit: 14 years 2 months ago by sozzled.
14 years 1 month ago #134102 by pepperstreet
Hello, just noticed in J! 1.5.26 - Kunena 1.5.x Upgrade to Kunena 2.0.2
that the Kunena Menu module is not created.
The menu and entries are there, but no mod_mainmenu module.
14 years 1 month ago - 14 years 1 month ago #134104 by pepperstreet
Tried to create a module manually, set all params like in another working installation etc.
No success?!?
The HTML markup shows just an empty ktab:
<div id="ktopmenu"> <div id="ktab"></div> </div>
EDIT:
Empty or not visible menu seems to be discussed here
So, this is not related to my missing module. As far as i understand from the mentioned thread, kunena menu needs to be in the main menu... I already had a single menu item there, and I want to keep the ItemID. So, I turned this existing menuitem into an ALIAS. pointing to my new Kunena Home Menuitem in Kunena Menu.
Works!
EDIT 2:
Funny..., accidently I did the same setup like in the wiki docs. You never stop learning! But I still wonder why it is working without an existing module. I deleted it again. Its not mandatory.
Last edit: 14 years 1 month ago by pepperstreet.
