Sticky K 2.0 general menu issues
I have merged your topic with one where the kind of question you have asked has been discussed before. It always helps if you read he FAQs page to begin with. The FAQs page explains that the "menu buttons", that you mentioned, are nothing more than a standard part of the Joomla menu system. Managing your menu is simply a case of using the Joomla Menu Manager (simple for some, perhaps, but a lot of people seem to have problems with the Joomla menu system).
When posting questions on the forum, it can sometimes help to post your configuration report. Your configuration report will show us (and you) exactly how you have set up your Kunena menu. Details about how to post your configuration report are also given in the FAQs page under the section What information should I include when I ask for help (including how to post my configuration report)?
I hope this helps.
many thanks
Gav
G'day, Gav, and welcome to Kunena.
There is no code to modify. The Kunena Menu is a Joomla menu and you can redefine menus and menu items using the Joomla Menu Manager.
