Sticky K 2.0 general menu issues
14 years 12 hours ago #136899 by sozzled
Replied by sozzled on topic Missing Kunena Menu
*** Topics merged ***
The answer is here
13 years 11 months ago #137099 by bking1300
Problem with update 2.0.3
Instalaltion smoothly.
But the forum does not appear ...
Joomla 2.5.8
Kunena 2.0.3 and modules and Pugin update ...
Can you help me
thank you
13 years 11 months ago #137102 by skybax
Replied by skybax on topic Problem with update 2.0.3 ?
go in backend Kunena Forum >> Forum Tools >> Menu Manager and see if you hace any conflict there.
13 years 11 months ago #137106 by sozzled
Replied by sozzled on topic Problem with update 2.0.3 ?
bking1300 wrote: Installed smoothly but the forum does not appear.
I think you will find your answer here, in this topic.
13 years 11 months ago #137145 by bking1300
Nope it's not the same problem, because if I do not see the menu I'll be happy again. This is the component that does not appear.
Better yet when I use that is noted on the video it destroys my position kunena_menu menu. elel for no longer exists. Although entenud module is not recreated.
And when I use the main menu is recreated on the forum home page forum does not spawns. Under 1.7.2 and everything works perfectly as before.
Since version 2 is the Beresina ... LA update created everything right but not component ... I just rebuilt 50 times
Do you have an idea ...
13 years 11 months ago #137376 by bking1300
I think if Kunena problems, and its advantage of being free this advantage is now a ruin for me time and patience.
I switch to something else because there are components that have a true support service and especially that work better ... ezet this mêm but are paying e is more economic production.
It is no longer what it was. Viewing it moves the question in another forum as this is not the same, are plsu 15 days to respond.
I actually created a confused and débruillle you with ...
In fact it is not confused Kunena Forum is forum ..
