Sticky K 2.0 general menu issues
14 years 3 months ago - 14 years 3 months ago #130212 by che1974
I hope you search for this .. (my english is very bad, i do not need it the last 20 years *lol)
and then ..........
on the same way you can get it on the "Main Menu" ->new Item (Kuena Forum)
i select this way .............
lg
che1974
Last edit: 14 years 3 months ago by che1974.
14 years 3 months ago #130214 by theodor
Well this only creates the Kunena menu, I dont see the tabs with the items I m creating above my forum.
14 years 3 months ago - 14 years 3 months ago #130220 by theodor
Well I have read the post here
www.kunena.org/forum/K-2-0-General-Quest...Kunena-Menu?start=60 and finally I made it !!
Following sozzled's instructions, this is how you get the Kunena menu (tabs) working after upgrade:
[assume that the main menu is your default menu]
- menus > main menu. Find your existing link to the Forum in the list of items. Trash it. Empty trash
- components > kunena. Go to Control Panel > Forum Tools > menu manager. Click on Trash Menu (top right) to rebuild the Kunena Menu
- return to menus > main menu. You will find a new link to the Forum that was automatically generated when yu rebuilt the Kunena Menu. It will have a status of 'unpublished' - change this to 'published'.
You should now find that the Kunena menu appears when you go to the Forum from your new main menu link - the missing menu tabs will now be there (I hope!)
Thanks for your screenshots !
Too bad that there is no stick post about this from the moderators.
Last edit: 14 years 3 months ago by theodor.
14 years 3 months ago #130234 by mitchell65
I had problems when i upgraded to V.2 on my Xampp localserver and that unfortunately does not appear to be sovable. So I thought I would test on my Wamp localserver. All went well with the upgrade but i have now lost the Kunena menu. Have checked all the detail and there is nothing I can see that has got changed but the menu does not now show. Any ideas please? It seems the upgrade causes some PHP problems, that's what I conclude anyway but I am not good with PHP!
Have a test host site that i could out the site on and give admin access if needed, thanks.
14 years 3 months ago #130238 by sozzled
Replied by sozzled on topic Missing Kunena Menu
*** Topics merged ***
Answered in this topic
14 years 3 months ago - 14 years 3 months ago #130322 by yigitusta9
hello everybody there was a problem with my kunena menu i deleted it and there is no button called create menu in kunena control panel
also there is no plugin position called kunena_menu
here how my panel looks like:
and no module position called kunena_menu:
Last edit: 14 years 3 months ago by yigitusta9.
