- Thank you received: 3
Sticky K 2.0 general menu issues
- keithyoung89
- Junior Member
I will start a new topic for this after I have double checked the issue.
As far as i'm concerned this topic (menu problem) is resolved and can be closed.
Thanks.
- keithyoung89
- Junior Member
Following sozzled's instructions, this is how you get the Kunena menu (tabs) working after upgrade:
[assume that the main menu is your default menu]
- menus > main menu. Find your existing link to the Forum in the list of items. Trash it. Empty trash
- components > kunena. Go to Control Panel > Forum Tools > menu manager. Click on Trash Menu (top right) to rebuild the Kunena Menu
- return to menus > main menu. You will find a new link to the Forum that was automatically generated when yu rebuilt the Kunena Menu. It will have a status of 'unpublished' - change this to 'published'.
You should now find that the Kunena menu appears when you go to the Forum from your new main menu link - the missing menu tabs will now be there (I hope!)
I hope I've left nothing out - please report back if it still does not work.
- keithyoung89
- Junior Member
