Sticky K 2.0 general menu issues
14 years 4 months ago - 14 years 4 months ago #128450 by arosscpa
Replied by arosscpa on topic The Kunena 2.0 Menu
First, I owe Sozzled an apology: MEA CULPA! MEA CULPA! MEA MAXIMA CULPA! I am sorry; in my frustration and ignorance I took a lot of my frustration out on you, and I apologize.
Second, for those having similar issues after upgrading to Kunena 2.0 or 2.0.1, you must 1) go into the plugins submenu under extensions. 2) Type "FORUM" into the Filter box and then hit "SEARCH." 3) For any plugins that are disabled/unpublished (showing a red button with a white dot) you must select them by checking the box on the far left. Once they are all selected, hit the enable button (green button with white check mark.) Do not leave any plugin with the word "forum" in it disabled when you leave the plugins page. I also recommend going into Kunena/Template Manager, going to the bottom right of the page, and selecting "NO" to the question about integrating the Blue Eagle Template with your site template.
There is still one issue left after doing all this. The tabs show as white on white in the template I am using, which is a CloudAccess/Rocket Theme template and may be specific to certain template designs. I will try and change the forum template to a basic Joomla template. If this works I will post that information in case it helps any one else.
Again, my sincerest apologies to Sozzled, and I hope this information is helpful to others.
Last edit: 14 years 4 months ago by arosscpa.
14 years 4 months ago #128452 by arosscpa
Yes, the white on white tabs are a function of the template, not anything to do with Kunena itself. The easiest fix is to use the Atomic template that accompanies each Joomla installation. In the alternative, and if you have sufficient skill, or know someone that does, you can change the CSS for your menu template.
14 years 4 months ago - 14 years 4 months ago #128454 by betteryouthanme
same problem here. i'm using JSN Dome template. The menu vanishs after updating Kunena. Trash menu dosn't help.
And if you go to a board category manually the menu appears again. But when i'm using the main link to my forum (in my main menu) the Kunena menu is not displayed, exactly like in the posts above.
Two things fill the mind with ever new and increasing wonder and awe - the starry heavens above me and the moral law within me. Immanuel Kant
Last edit: 14 years 4 months ago by betteryouthanme.
14 years 4 months ago - 14 years 4 months ago #128462 by sozzled
Replied by sozzled on topic The Kunena 2.0 Menu
aarosscpa: Apology accepted humbly. I have actually been trying to get help (myself) from my colleagues that would answer your main question; viz. your missing menu.
In your case this is your Kunena menu structure (below):
You had two menu items in your (top-level) mainmenu module.
The first item (636) points to a non-existent target. You need to unpublish and remove this item.
The second item (764) points to (765) - it is an alias menu - and it needs to be published. You may want to rename this to "Let's Talk - FIFH Discussion Boards"
I did say that the Joomla menu system is a real pain in the neck.
Last edit: 14 years 4 months ago by sozzled.
14 years 4 months ago #128523 by alsthom
Replied by alsthom on topic After upgrade - no Menu
Have you create a menu alias pointing to kunena?
14 years 4 months ago #128616 by Matias
@keithyoung89: kunena_menu position doesn't exist in Kunena anymore, we are now rendering the menu for ourselves inside Kunena.
For everyone: configuration report of Kunena 2.0.1 contains all Kunena related menu items, so seeing it will help to solve your issues.
