Sticky K 2.0 general menu issues
14 years 4 months ago - 14 years 4 months ago #127539 by coder4life
Replied by coder4life on topic The Kunena 2.0 Menu
No you cannot uninstall K2.0 and reinstall K1.7.2. Please follow release notes Kunena 2.0 Release Notes . You can restore from a backup.
Also I believe Rules was a custom menu type before, if I am not mistaken.
Last edit: 14 years 4 months ago by coder4life.
The following user(s) said Thank You: arosscpa
14 years 4 months ago #127646 by Matias
Replied by Matias on topic After upgrade - no Menu
In Kunena 2.0 I decided to remove most of the dirty hacks we had in the previous version and just use the plain menu system from Joomla. The reasoning was that people were having so many issues because of the hacks and I had difficulties to understand the code, so making fixes into it were becoming more and more difficult.
This is how Kunena works:
1) Check if current menu item has parent called "Kunena Forum >> Home Page"
2) Display menu which is under that menu item
Basically the effect is the same as creating menu module that displays sub-menu starting from Home Page level+1.
If you don't have menu under the current menu item, no forum gets displayed.
Joomla does have a way how to make menu aliases that are really located somewhere else, e.g. in another menu. By using that you can point your menu item to Kunena Menu. By default, Kunena adds one link to the default menu (marked with star).
14 years 4 months ago #127687 by jamarchi
Replied by jamarchi on topic After upgrade - no Menu
Hi I don´t know how I can see the menu in the index, as you can see inthe image attached but when i clic in any item I got the error "500 Internal Server Error"
Can you please help me
14 years 4 months ago #127753 by sozzled
Replied by sozzled on topic After upgrade - no Menu
Please read HTTP 500 Internal Server Error for information on how to diagnose the cause.
14 years 4 months ago - 14 years 4 months ago #127763 by jamarchi
Hi Sozzled
I fixed the error with user and the menu showed up again, I don´t know if the issue with the user opction is related with the other issue.
But thank you for your answer
Regards,
Last edit: 14 years 4 months ago by jamarchi.
14 years 4 months ago #127783 by sozzled
I think we are finished here.
