Sticky K 2.0 general menu issues
14 years 4 months ago - 14 years 4 months ago #129391 by betteryouthanme
Replied by betteryouthanme on topic Missing Kunena Menu
I am running Joomla 1.5.26, ja_purity_ii and I installed k 2.01. Installation went smooth. In general, seems to work well. The biggest (only?) issue I have are the menus (i.e. the tabs). I link directly to the kunena menu "recent topics" from my main menu. The topic list is displayed correctly - but NO tabs on the top. IF / WHEN I click on a single entry in the discussion list, the individual entry is displayed AND the tabs magically appear, and the tab items work correctly as long as I stay within Kunena. Even the recent topics tab item works fine when I link from within Kunena. If I navigate back out of Kunena to another section, and then click on the main menu item linking me to Kunena, the issue is back.
I've read all of the entries in this thread, and I've used the Kunena tool to trash and re-constitute the menus, but the problem persists. Any ideas?
Just wanted to post that it works now as well for me, i just changed the menu tye of my main menu link to alias menu type. That's all.
Two things fill the mind with ever new and increasing wonder and awe - the starry heavens above me and the moral law within me. Immanuel Kant
Last edit: 14 years 4 months ago by betteryouthanme.
The following user(s) said Thank You: achartier
14 years 4 months ago #129782 by kallle
Replied by kallle on topic No Kunena-Menu to see
After Updating from 1.7... to 2.0.1 there is NO KUNENA-MENU!
In Joomla-Menu-Konfiguration all seems to be like before update. Only the menuentry I had to adjust new, because it has jumped to a subsite of Kunena-Forum.
The Joomla-Modul for Kunena-Menu also is configured right.
But no Menu to see anywhere...
What may be wrong?
(Joomla 2.5.6 / Template: New Eagle 2.0 / AceSEF 2.5.2)
Thank you very much for hints
kallle
14 years 3 months ago - 14 years 3 months ago #129789 by kallle
Just I see, that the
<div id="ktopmenu">
isn't generated anymore since update!
If I push the Kunena-Menu form kunena_menu-position to the Joomla-left-position, I can see and use it.
But if I will push it return to "kunena_menu" then there isn't any choice for it: "kunena-menu" is gone away in the Joomla-list of possible positions!
What is the reason for this behavior of kunena_menu-position?
And now I see there isn't any possibility to "create menu" in the kunena-components-adminarea!
Regards
kallle
Last edit: 14 years 3 months ago by kallle.
14 years 3 months ago #129816 by kallle
Replied by kallle on topic Missing Kunena Menu
The Kunena version 2.0.1 has a basical bug.
The failure goes deeper.
When will the version 2.0.2 come out?
Kind regards
kallle
14 years 3 months ago - 14 years 3 months ago #129839 by Jiminimonka
Replied by Jiminimonka on topic Missing Kunena Menu
Please read the rest of this topic and follow the instructions provided by here by sozzled.
Please read the FAQ.
Only one question per topic.
Last edit: 14 years 3 months ago by sozzled. Reason: fixed broken URL
14 years 3 months ago #130207 by theodor
Spent so many hour to look for some info's about this and nothing!
In the previous versions was a hell to setup the menu, in 2.0.1 there is no instructions at all !!
Only some posts referring for some alias and that's it .
Could someone spent some minutes to write some instructions about it ???
