Solved K 3.0.2 message preview not working
13 years 4 weeks ago #149981 by freedomcoach
Hi Sozzled:
Since Kunena and Community Builder and two very popular Extensions it seems we should be able to find users who are running both of them, right? I'd love to learn what they say and would love to get a fix soon. In the meantime I'm trying to get my users to re-upload their photos to the Kunena profile.
Howard
13 years 4 weeks ago #150010 by Matias
I've talked with JoomlaPolis people a bit and nobody has seen this issue before. I have no idea why it might be failing -- maybe sozzled can share his account to your site with me.
13 years 4 weeks ago #150016 by sozzled
I do not use Community Builder these days on my websites. I have asked people on the Kunena testing team (some of whom use Community Builder) to share their insights on this matter. There are three facts that I can report:
Fact 1: To date, only two people have reported on the forum that there seems to be an issue using the Kunena - Community Builder integration plugin and, when it's enabled, it prevents the message preview feature working.
Fact 2: No one else has confirmed that these same conditions occur on their sites. Anecdotally, from the various discussions I have had on Skype (where I asked others to contribute to this topic - and they didn't), one person said that he had tested K 3.0.3 with CB and he had no problems; but that is just hearsay. For this reason, I cannot say if it is a CB issue or not. If someone else replies to this topic with confirming evidence of the incolvement between CB and the message preview problem, then this topic could be moved to a more appropriate category. Until then, this remains a topic for the "general questions" category.
Fact 3: I have not encountered this problem on any website that I have built myself but, then again, I do not use CB these days.
I do not remember the account username/password that Howard setup for testing his website.
13 years 4 weeks ago #150022 by Matias
My guess is that there's some plugin or setting in CB which causes this issue. As the issue seems to relate to CB integration, the easiest way to test it out is trying to enable and disable various settings and other plugins in order to fing the exact cause of the issue.
What happens if you don't disable Kunena - CB plugin, but just the settings in it? Which setting causes the issue or is it global? Also what happens if you disable integration or parts of it in CB itself?
13 years 1 week ago #150600 by civilizationitalia
I'm very busy at work at the moment.
I will try further combinations as Matias suggests.
I'll let you know... As soon as possible.
12 years 11 months ago #151688 by jwill
I just started having the missing preview problem. The preview pane was working just a couple of days. Three things have recently changed. Upgraded to 3.0.3 Kunena, upgraded to 2.5.17 Joomla, and upgraded to version 6.4.3 of the Warp template framework. I reverted back to the previous version of Warp framework and the problem did not go away. Unlike previous users with the problem, I do not use Community Builder and I am hosted on SiteGround. The only change to core Kunena were to the language file.
htaccess: Exists | PHP environment: Max execution time: 45 seconds | Max execution memory: 128M | Max file upload: 48M
Joomla default template details : tk_gen_multicolor_11 | author: ThemeKat | version: 1.1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.3 | creationdate: 2013-10-20
Kunena version detailed: Kunena 3.0.3 | 2013-10-20 [ Bifrost ]
Plugins: Search - Kunena Search 3.0.1
Modules: Kunena Latest 3.0.1
I would appreciate any advice you can offer.
Jim Williams
Time to create page: 0.170 seconds
