Solved K 3.0.2 message preview not working
13 years 1 month ago - 13 years 1 month ago #149339 by sozzled
Way back in msg #3 I wrote this:
sozzled wrote: Howard, this is what I wrote in the other topic you started 3 days ago:
sozzled wrote: Maybe you are having problems because you are using the K 1.7.2 Blue Eagle template and you have not updated Kunena Search plugin and Kunena Login module to the latest version?
Also, your version of Joomla is out of date and you should upgrade it.
What I wrote, 3 days ago, applies the same here, too. Mortti's advice today is the same as my advice given 3 days ago, If you are unprepared (or unwilling) to update unsupported versions of software used on your website, there is not a lot that we can do to assist you.
The key question to this topic is whether the message preview facility ceases to work in the same ways as we were able to identify when you were using K 2.0.x. I vaguely remember those circumstances but the exact details of the case escape me at this very moment. Can we reproduce the problem here at K.org, for instance?
According to your configuration report posted a couple of hours ago, you are still using the Blue Eagle template designed for K 1.7.2. This is probably the reason that the message preview is not working on your website.
If you would like to try the Blue Eagle template designed for K 3.0.2 maybe you will see a difference? If you do not wish to use the Blue Eagle template designed for K 3.0.2 then I do not think we will find a solution to your problem, sorry.
I have given you several tips for things to change in the past. You've changed one or two of them but there's still a lot you can do.
For example, the Kunena Login 2.0.4 module that you are using is unsupported for K 3.0.2. Update it or uninstall it. Let's get your software up-to-date, let's eliminate as much as we can (there are no wild goose chases here - it's just a commonsense approach to dealing with these kinds of things). What I have suggested is not a sure-fire guarantee but at least we are eliminating all the possibilities. At the end of the day the problem may have nothing to do with Joomla, Kunena or the things you have installed; the problem may come down to your webhost. I am just trying to eliminate the variable contenders.
Last edit: 13 years 1 month ago by sozzled.
13 years 1 month ago #149354 by freedomcoach
Sozzled,
I have repeatedly said over and over again that I'm willing to make any changes that are needed to get my preview working yet you continue to portray this attitude towards me of "we can't help you if you won't make the changes". I do not get why you remain so negative and critical of me. Seems to be a remnant of past conversations.
I would appreciate it if you would shift your attitude to one of support. I'm not some renegade obstinate child!! Perhaps, you've become frustrated and resentful over the years with so many people who fail to follow instructions.
I switched templates and it made no difference with the preview. I will install the latest search plugin too. I do not use the Kunena Login on my site because I prefer to use other login modules.
Do you believe the Kunena login module must be actively used to make the Kunena preview work correctly? This sounds pretty weird to me. Just being honest.
More soon!
Howard
13 years 1 month ago #149355 by freedomcoach
I just checked and see that my Kunena search plugin is 3.0.1, the current latest one on this site.
I also just installed the latest Kunena login module and activated it.
I also switched my default template to the latest 3.01 Blue Eagle template available in the Kunena template manager.
The preview is still blank.
13 years 1 month ago - 13 years 1 month ago #149363 by sozzled
Ifreedomcoach: I would prefer to not discuss the characterisations you made about me in your penultimate post but, as you have chosen to make an issue of it, let me respond by explaining why I feel it's to everyone' advantage to "level the playing-field".
Fact 1: everyone's website environment is different. The world would be a wonderful place, indeed, if everyone's site was hosted on the same shared server (where none of us had to worry about maintaining different versions of SQL, PHP, operating system, etc). If everyone was using the same version of Joomla, the same site template, Javascript and other site utilities, would it not be fantastic (from a support perspective)? Why not use the same SOE approach in webcraft as corporations take when they deploy ICT resources in the workplace? We would cut our support costs to a fraction of what we now expend. The reality is that we do not enjoy this support utopia because everyone's site is different; everyone wants to march to the beat of a different drum and that's a good thing. But it's because of this desire to beat a discordant beat that we get these "support" questions. It is therefore our task to is try to identify a tune which we can recognise. So, I beg of you, try to put yourself in my shoes (before you label me in the way you have done) if I don't recognise the "melody" that you want me to hear.
Fact 2: you know your website better than I know your website. There's no value judgement attached to that statement; it's a fact. I'm not trying to change the way that you've built your site but I am asking you to consider - for one big moment - that there's a possibility that, because you've done things in your own individual way, your unique - dare I day - "unconventional" approach may be responsible for the situation in which you currently find yourself.
Fact 3: we cannot reproduce this problem in our own testing environment using the latest public release of Joomla (J! 3.1.5), using any of the default templates that are installed with Joomla, using an unmodified installation of K 3.0.2 - by "unmodified" I mean no changes to the configuration, whatsoever - without the added complications of Kunena add-ons of differing versions, or other software like uddeIM or Community Builder - or any other of the several ingredients added to your software soup. "If you eliminate all the possibilities, whatever remains, no matter how improbable, must be the solution."
I could save myself a lot if time by not explaining the analytical process I've developed over the past 40+ years of my IT career and, maybe, I could save myself a lot of trouble by simply ignoring the problems that are going to give me the most trouble. But I like you, Howard, and I admire the work you do; however, if we get do not get some traction on this problem of yours, we're never going to arrive at the solution.
Fact 4: everyone's approach to problem solving is different ... and, even within the same team, an inconsistent approach can cause other problems. My approach is simple: let's attempt to normalise things, to eliminate the guesswork. After years of pleading with people to provide updated information - the configuration report - every time they make a change, we've given up. We've never gotten anywhere with that approach. The new approach is now to not ask for that information. If people don't want to give us that kind if information then I given up asking for it; sometimes it's better to let people work things out for themselves. ;)
So, what's the conclusion? We're no closer to resolving your problem than we were a month or more ago.
Want to know my guess why this message preview doesn't work? I think it's your webhost. Want to know a way to solve it? Try a different webhost. Does this sound like a knee-jerk response from someone who doesn't care? Yes, if that has been my opening gambit, I would have to agree. If someone told me "go buy a better webhost" to each and every problem that I asked for help, I would be most annoyed. But, to be honest with you, Howard, we're pretty much running out of options available to us, aren't we? So, that's my last-resort option but I don't think we've reached that stage, yet.
freedomcoach wrote:
I also switched my default [Kunena] template to the latest 3.01 Blue Eagle template available in the Kunena Template Manager
One small problem with that: the latest version available should be the Blue Eagle template designed for K 3.0.2. :dry:
If you do not use the Kunena Login module then uninstall it.
I want to make two final points:
1) can we reproduce this problem here, at www.kunena.org ; and
2) to avoid the likelihood of misunderstanding what versions of whatever you are using, can I see your updated configuration report, please?
13 years 1 month ago #149369 by sozzled
I have another question for you. Because the message preview feature is essentially an implementation of AJAX , you should check your PHP settings to make sure that you have JSON enabled. Can you do that please and let us know what are the two PHP settings relating to JSON support on your site.
Thanks. :)
13 years 1 month ago #149434 by freedomcoach
Hi Sozzled:
I have no disagreement with your troubleshooting approach of normalizing. My Joomla hosting company is cloud access.net. They are in fact a joomla exclusive hosting company with extremely knowledgeable and highly supportive people. They consistently go above and beyond any hosting company I've ever seen to make things work and customers satisfied. I'm totally happy to ask them about my PHP settings as you described.
BTW, my Kunena preview did work okay just a little while back. I'm pretty sure it was with Kunena 3.0 but unfortunately I'm not remembering when exactly it stopped working.
When you say my approach with my website or Kunena is unconventional, please let me know what is unusual about having a discussion forum link on my main menu which goes directly to login and to forum? I thought this is pretty standard. My current configuration report is below.
htaccess: Exists | PHP environment: Max execution time: 660 seconds | Max execution memory: 512M | Max file upload: 360M
Joomla default template details : BTC2012 | author: Illiana Technology | version: 1.0 | creationdate: Unknown
Third-party components: CommunityBuilder 1.9 | UddeIM 2.9
Plugins: Search - Kunena Search 3.0.1
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1 | Kunena Login 3.0.1
Time to create page: 0.161 seconds
