Solved K 3.0.2 message preview not working
13 years 2 months ago - 11 years 10 months ago #148508 by freedomcoach
It seems that an old problem has reared its ugly head again, the famed Preview not working. I'm running the very latest K3.02 and preview window remains blank.
Fortunately, posts are saved properly with no difficulties. I see that there's been a previous thread on this topic but it is closed hence my posting this here. PLEASE advise how to remedy this! My Kunena profile is below.
htaccess: Exists | PHP environment: Max execution time: 660 seconds | Max execution memory: 512M | Max file upload: 360M
Joomla default template details : BTC2012 | author: Illiana Technology | version: 1.0 | creationdate: Unknown
Third-party components: CommunityBuilder 1.9 | UddeIM 2.9
Plugins: Search - Kunena Search 2.0.4
Modules: Kunena Login 2.0.4
Last edit: 11 years 10 months ago by 810.
13 years 2 months ago #148510 by Mortti
Hi freedomcoach,
I can see that you have old versions of J! 2.5.xx, Kunena Search plugin and Kunena Login module at least...
...also there is old Kunena Template : Kunena default template details : Blue Eagle (default) | author: Kunena Team | version: 1.7.2 | creationdate: 2012-01-31
Can you please update these at first and try then again?
13 years 2 months ago #148516 by sozzled
Howard, this is what I wrote in the other topic you started 3 days ago:
sozzled wrote: Maybe you are having problems because you are using the K 1.7.2 Blue Eagle template and you have not updated Kunena Search plugin and Kunena Login module to the latest version?
Also, your version of Joomla is out of date and you should upgrade it.
What I wrote, 3 days ago, applies the same here, too. Mortti's advice today is the same as my advice given 3 days ago, If you are unprepared (or unwilling) to update unsupported versions of software used on your website, there is not a lot that we can do to assist you.
The key question to this topic is whether the message preview facility ceases to work in the same ways as we were able to identify when you were using K 2.0.x. I vaguely remember those circumstances but the exact details of the case escape me at this very moment. Can we reproduce the problem here at K.org, for instance?
13 years 2 months ago #148633 by andrerds
Hello friends, I need your help,
this error and very annoying to click on the preview, does not appear.
I came to uninstall Kunena instalalei and again, the error is not more left .. I do not know what else to do, I'm using Kunena 3.0.2 | 18.08.2013, and Joomla 2.5.14 ..
Please help me.
Grateful ...
13 years 2 months ago #148681 by freedomcoach
Found the new Kunena search plugin but not clear where to download new template. I do not use the Kunena login module.
13 years 2 months ago #148682 by rich
This template is already installed (after Kunena upgrade). Go in backend to "Kunena > Templates" and chose the template Blue Eagle 3.0 as default.
Time to create page: 0.146 seconds
