Solved K 3.0.2 message preview not working
13 years 1 month ago #149211 by sozzled
If you are having problems using a Kunena template that was not designed, developed, supported or maintained by the Kunena team, we advise you to contact the developer of that template for their advice.
13 years 1 month ago #149261 by robin76
As I said before problem is not of a single template.I have the same on latest kunena template and with or without joomla standard template
13 years 1 month ago #149262 by 9themestore
Hi robin,
You try to switch the Blue Eagle template, if it work fine you need contact with the your template provider and request they resolve your problem. I think you are using the old version.
Regards
13 years 1 month ago #149264 by robin76
Hi, I am sorry, but maybe I' ve been not clear, I already tried with every kind of template combination....
13 years 1 month ago #149270 by xillibit
Do-you have looked in your firebug console if you can see something ?
Do-you have a test account on your site ?
13 years 1 month ago #149338 by freedomcoach
I have never ever used any template for Kunena other than the one provided by Kunena. My preview is still blank.
There is also no problem with my menus either. I use a menu item that logs me directly into the Discussion Forum and there has not been any issue with this menu in a very long time. I'm also running the very latest version of Joomla.
My latest configuration is below and I'm happy to update any item you really believe can be a culprit for the preview problem but please lets not go on a wild goose chase and waste everyone's time. ok?
htaccess: Exists | PHP environment: Max execution time: 660 seconds | Max execution memory: 512M | Max file upload: 360M
Joomla default template details : BTC2012 | author: Illiana Technology | version: 1.0 | creationdate: Unknown
Third-party components: CommunityBuilder 1.9 | UddeIM 2.9
Plugins: Search - Kunena Search 3.0.1
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1 | Kunena Login 2.0.4
Time to create page: 0.155 seconds
