- Thank you received: 3
Kunena 7.0.7 Released
configuration report
Sticky K 2.0 general menu issues
- keithyoung89
- Junior Member
14 years 3 hours ago #129072
by keithyoung89
Replied by keithyoung89 on topic SOLVED: Menu tabs missing after upgrade to v2.0.1
Yes ... it now works. I'll write up detail for others in morning as it was a bit obscure.
Thanks sozzled.
Thanks sozzled.
14 years 3 hours ago #129074
Replied by sozzled on topic Menu tabs and emoticons missing after upgrade to v2.0.1
keithyoung89: I have not read through the whole topic but you asked two questions - this is not a good thing to do; we prefer one question per topic. Did you resolve the issue with the missing emoticons? If not, can you please start a new topic. I would like to close this topic and mark it as "solved". Thank you.
- keithyoung89
- Junior Member
14 years 3 hours ago #129075
by keithyoung89
Replied by keithyoung89 on topic Menu tabs and emoticons missing after upgrade to v2.0.1
I should have refered to topicicons, not emoticons.
I will start a new topic for this after I have double checked the issue.
As far as i'm concerned this topic (menu problem) is resolved and can be closed.
Thanks.
Thanks.
14 years 2 hours ago - 14 years 2 hours ago #129080
Please start a new topic relating to topic icons. Thank you. The subject (in this topic) refers to "emoticons", not topic icons.
Last edit: 14 years 2 hours ago by sozzled.
14 years 2 hours ago #129082
by kross76
Replied by kross76 on topic Menu tabs and emoticons missing after upgrade to v2.0.1
I'll look for the write up by keithyoung89 on the Menu Problem, and try it. And let you know if it's solved. keithyoung89, please be detailed in your description of the solution. Thanks ...
- keithyoung89
- Junior Member
13 years 11 months ago #129098
by keithyoung89
Replied by keithyoung89 on topic Menu tabs missing after upgrade to v2.0.1
This solution refers only to the missing menu tabs following upgrade. A new topic will be started regarding missing topicicons.
Following sozzled's instructions, this is how you get the Kunena menu (tabs) working after upgrade:
[assume that the main menu is your default menu]
- menus > main menu. Find your existing link to the Forum in the list of items. Trash it. Empty trash
- components > kunena. Go to Control Panel > Forum Tools > menu manager. Click on Trash Menu (top right) to rebuild the Kunena Menu
- return to menus > main menu. You will find a new link to the Forum that was automatically generated when yu rebuilt the Kunena Menu. It will have a status of 'unpublished' - change this to 'published'.
You should now find that the Kunena menu appears when you go to the Forum from your new main menu link - the missing menu tabs will now be there (I hope!)
I hope I've left nothing out - please report back if it still does not work.
Time to create page: 0.275 seconds
