Solved K 2.0.2, K 2.0.3: problems with preview
14 years 1 month ago #134950 by xillibit
Someone can try to install Kunena 2.0.1 and just apply this fix : github.com/Kunena/Kunena-2.0/commit/957b...a6f3e31a75473281f5a3
I want to be sur that this fix is causing the issue
14 years 1 month ago #135080 by deltafidesign
I've found the plugin that generate the issue: Kunena plugin for Community Builder
14 years 1 month ago #135081 by xillibit
Thanks for report, i will try to reproduce the issue on my local machine
14 years 1 month ago - 14 years 1 month ago #135082 by roland_d_alsace
deltafidesign wrote: I've found the plugin that generate the issue: Kunena plugin for Community Builder
Hi deltafidesign and "Bravo!"
...I confirm it's this plugin.
Last edit: 14 years 1 month ago by roland_d_alsace.
14 years 1 month ago #135105 by xillibit
@deltafidesign and @roland_d_alsace : can-you post here your Kunena report configuration settings ?
14 years 1 month ago - 14 years 1 month ago #135107 by roland_d_alsace
Hi Xillibit.
You cannot reproduce the problem ?
If you want i make you a copy of my web site with an admin and ftp access, where you can make all the test you want ?
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 384M | Max file upload: 8M
Joomla default template details : pneuboat_boating_2012_2 | author: Angie Radtke | version: 2.5.0 | creationdate: 25 November 2009
Kunena default template details : kunena pneuboat 2012 | author: Ordi Genie | version: 1.0 | creationdate: 2011-08-05
Third-party components: CommunityBuilder 1.8.1
Plugins: Content - Kunena Discuss 2.0.2
Modules: Kunena Latest 2.0.2 | Kunena Stats 2.0.2 | Kunena Search 2.0.2
Time to create page: 0.155 seconds
