Solved K 2.0.2, K 2.0.3: problems with preview
14 years 2 months ago #133388 by sozzled
14 years 2 months ago #133898 by roland_d_alsace
xillibit wrote: The thing which has changed between k2.0.1 and 2.0.2 it's that : github.com/Kunena/Kunena-2.0/commit/957b...a6f3e31a75473281f5a3
Hi xillibit.
Do you think that i need to change administrator/components/com_kunena/libraries/controller.php v.2.0.2 by old v.2.0.1 for testing ?
...i my case preview does never work (SEF enbabled or disabled the problem is the same).
14 years 1 month ago #134405 by pequeno74
Preview doesn´t work for me too.
I have two websites with kunena 2.0.2. In one works and another does not.
I tested with default joomla template and does not work.
14 years 1 month ago #134407 by sozzled
What are the differences between your two sites - the one where the preview works and the one where the preview does not? Are they hosted on the same platform? Do you have a different mixture of software components? When you identify the key difference(s) then you are well on the way to resolving the problem.
The following user(s) said Thank You: pequeno74
14 years 1 month ago #134408 by pequeno74
Hello sozzled
They are hosted in the same platform - No platform problem.
They have different templates, but the problem occurs with joomla default tempalte too - No joomla template problem.
I'm testing the different components
14 years 1 month ago #134415 by pequeno74
SOLVED.
In my case, I inserted code in kunena.php that caused the problem.
Delete the code and works fine.
