Solved K 2.0.2, K 2.0.3: problems with preview
14 years 1 month ago #134422 by roland_d_alsace
pequeno74 wrote: SOLVED.
In my case, I inserted code in kunena.php that caused the problem.
Delete the code and works fine.
Hi pequeno.
Can you say more ?
What code have you deleted in kunena.php (have you made a downgrade of kunena.php in 2.0.1) ?
Have you the same ajax problème like me html return instead of json ?
Thanks.
Regards.
14 years 1 month ago #134523 by freedomcoach
This issue of your preview remaining blank may be more revealing than meets the eye. I suggest that you do an experiment. Open the preview window before typing your message, then start typing slowly and see if the preview window slowly catches up.
If and when you see the preview go blank try saving your post and see what happen. You may get an error message saying your message box is blank when you know that it isn't. If this occurs, we will finally have someone experiencing the same issue I have posted here that no one is responding to.
Sozzled, please do not consider this post off topic, it is not. There is relevance here worth some investigation!
14 years 1 month ago #134534 by 810
I found a bug in a Phoca plugin. So if you are using that, the preview breaks.
If you don't use that plugin. Please typ the plugins that are you using.
regards 810
14 years 1 month ago #134595 by pequeno74
Hi pequeno.
Can you say more ?
Thanks.
Regards.
Sorry, I had problems with my internet connection.
Have you made changes to kunena.php? If so, try one without change.
I don´t know what my problem was.
In my kunena.php, before
<?php
I put a text with <h2> label.
14 years 1 month ago #134842 by deltafidesign
When I click on the preview button it opens the box but no message is shown. Why?
14 years 1 month ago #134853 by xillibit
Replied by xillibit on topic No preview for messages
Maybe because you have a plugin or javascirpt which conflicting with it.
Time to create page: 0.172 seconds
