Solved K 2.0.2, K 2.0.3: problems with preview
14 years 1 month ago - 14 years 1 month ago #135117 by sozzled
roland_d_alsace: These are the plugin settings in your case:
Kunena - UddeIM Disabled
As you can see from the way that I've colour-coded the information, there are some "conflicting" settings. Perhaps it would help if you changed the settings so that you only used CB for the the login, avatar and profile and use Joomla for access.
The setting for CB's private message requires additional software to make this work. I do not know whether CB still has a private message feature. That's something you might like to ask the folks at Joomlapolis about. If you do not have the CB "private messaging system" software add-on installed on your site, you should disable this option.
This may or may not solve the problem but I would like you to try these settings to see if it works in your case.
Last edit: 14 years 1 month ago by sozzled.
14 years 1 month ago #135118 by roland_d_alsace
Hi sozzled and thanks for your work.
I have made the change that you suggest, but the problem is the same.
What do you think about my suggest in my post above ?
Here my new K config...
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 384M | Max file upload: 8M
Joomla default template details : pneuboat_boating_2012_2 | author: Angie Radtke | version: 2.5.0 | creationdate: 25 November 2009
Kunena default template details : kunena pneuboat 2012 | author: Ordi Genie | version: 1.0 | creationdate: 2011-08-05
Third-party components: CommunityBuilder 1.8.1
Plugins: Content - Kunena Discuss 2.0.2
Modules: Kunena Latest 2.0.2 | Kunena Stats 2.0.2 | Kunena Search 2.0.2
14 years 1 month ago #135120 by 810
ok, There is a bug in CB 1.8.X
Soon CB 1.9 will be released. The bug in fixed in there. and the preview is working again.
14 years 1 month ago #135121 by roland_d_alsace
810 wrote: ok, There is a bug in CB 1.8.X
Thanks 810
CB 1.9.0 RC is available.
I will test it with K 2.0.2 tomorrow.
14 years 1 month ago - 14 years 1 month ago #135193 by roland_d_alsace
Hi.
Today i have made some test.
Before upgrade CB i have transfered to a new local server.
I put my local configuration.php file and surprise : no preview problem.
After comparing the joomla configuration from production and from local test site :
Seearch engine urls : Yes
Use URL Rewriting : Yes
Adds Suffix to URL : Yes
-> preview problem
and with :
Adds Suffix to URL : No
-> preview is good.
After testing differents configurations, the problem is only linked to With Adds Suffix to URL : Yes.
With Adds Suffix to URL : Yes, I have upgrade to CB 1.9RC and (sorry 810) CB 1.9 don't fix the problem :S .
I think that with CB and SEO html sufix, ajax request return html instead of json.
(We have already detected in a precedent reply, that the problem is that ajax preview request return html instead of json)
Here is my new test configuration with CB1.9 (and always previem problem) :
htaccess: Missing | PHP environment: Max execution time: 3000 seconds | Max execution memory: 1024M | Max file upload: 128M
Third-party components: CommunityBuilder 1.9 RC
Last edit: 14 years 1 month ago by roland_d_alsace.
The following user(s) said Thank You: zomblaa
14 years 1 month ago #135209 by 810
@roland_d_alsace
I have tested with K2.0.3-dev version in the new version we have fixed some js issue's. Maybe the next release will solve your problems. Wil be released soon.
regards 810
Time to create page: 0.172 seconds
