Merged Problems with Gravatar avatar images
13 years 9 months ago #140147 by jemecb
Registered users cannot change their avatar image. Change or Save button does not work. Kunena gravatar integration is disabled.
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 256M | Max file upload: 50M
Joomla default template details : shaper_simplicity_ii | author: JoomShaper.com | version: 1.5.0 | creationdate: Jan 2011
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 2.0.3 | creationdate: 2012-11-24
Kunena version detailed: Kunena 2.0.3 | 2012-11-24 [ Reconciliation ]
Third-party components: UddeIM 2.8
Plugins: Search - Kunena Search 2.0.1
Modules: Kunena Latest 2.0.1 | Kunena Stats 2.0.1 | Kunena Login 2.0.1 | Kunena Search 2.0.1
13 years 9 months ago - 13 years 9 months ago #140168 by sozzled
jemecb: I do not think your question relates to whether or not you have enabled the Kunena - Gravatar plugin. I suspect your issue is covered by the range of problems that are discussed, broadly, in message #1 of Before you post your question, read this first .
You're report shows that you are using outdated versions of other Kunena add-ons . Please update those things to the latest version..
Last edit: 13 years 9 months ago by Jiminimonka.
13 years 9 months ago #140223 by jemecb
Yes, I was aware of older add-oms, these are now updated. The problem still exists as did before. I have jquery load turned off in template settings. Checking other solutions...
13 years 9 months ago #140224 by sozzled
I do not understand how your question relates to Gravatars. Can you explain how your question relates to Gravatar avatars, please?
13 years 9 months ago #140226 by jemecb
Sorry, could you move my posts to appropriate topic?
13 years 9 months ago - 13 years 9 months ago #140228 by sozzled
I think that the "appropriate topic" in your case is Before you post your question, read this first . Seems to me that you have a Javascript library conflict that is preventing your users being avoe to press the Save button that would save their changed avatar image.
Last edit: 13 years 9 months ago by sozzled.
Time to create page: 0.178 seconds
