Merged Problems with Gravatar avatar images
13 years 9 months ago #129454 by sozzled
TKtemp wrote: ... so if you activate integration all users must have Gravatar account or no avatar.
... as opposed to what? If you turn on the Gravatar integration, people either will have a Gravatar account - and, possibly they will have a Gravatar avatar image - or they will have the "no avatar" avatar image. It's obbvious that people will have one or the other, isn't it? Did I misunderstand something otherwise intended? :unsure:
13 years 9 months ago - 13 years 9 months ago #129474 by Walander
Hi giorgio!!
I had exactly the same problem, which is now cured, I achieved it the following way....
1. Go to "Plug-in Manager" and ensure that the "Gravatar" plug-in is disabled.
2. Go to the Kunena control panel, and click on "Forum Configuration".
3. Click on the "Avatars" box.
4. Ensure that the "Use Avatars Gallery" box is set to "NO".
Now go to your "User Profile", click on "Edit" and you will discover an additional "Avatar Image" box. Click on this and you are able to "BROWSE" and "SAVE" your chosen Avatar.
Simples!!!!
Hope this helps!! ;)
Last edit: 13 years 9 months ago by Walander.
13 years 9 months ago #129491 by sozzled
Walander wrote: 2. Go to the Kunena control panel, and click on "Forum Configuration".
4. Ensure that the "Use Avatars Gallery" box is set to "NO".4. Ensure that the "Use Avatars Gallery" box is set to "NO".
These steps should be unnecessary, in my opinion, but in these rare cases maybe this is something the development team should investigate further. Our difficulty is creating an environment that mimics the cases reported in this topic.
13 years 9 months ago #129495 by Walander
Sorry...but it was I had to do to get MY system to work. I was just trying to help giorgio??? :(
13 years 9 months ago #129499 by sozzled
We appreciate your help, Walander, and I wasn't saying otherwise. I was merely stating my surprise that you would need to perform steps 2-4 of your procedure, that's all. :)
13 years 9 months ago #129561 by Walander
OK thanks!!
I was just being a little sensitive, being a newbie and all that. ;)
Time to create page: 0.308 seconds
