Merged Problems with Gravatar avatar images
13 years 1 month ago #143630 by da8iwr
Hi there, sorry if this already answered, but i have searched and cant see it anywhere.
I have everything installed correctly (latest versions of Kunena 2.0.4 and Joomla 2.5.11), the settings in the config are set so you can upload avatars and also use the avatar library... but on the front end it is not showing the avatar tab in edit profile like it does on this site?
Anybody any ideas?
Many thanks
Ian
13 years 1 month ago #143638 by sozzled
I believe we can answer this question quickly if we see your configuration report. It is my guess that you should see Problems with Gravatar avatar images
13 years 1 month ago #143677 by da8iwr
Hey thanks for that, I didnt even know you could do a config report! :)
I just checked and my gravatar plugin is on.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 20M
Joomla default template details : gk_the_real_design | author: GavickPro | version: 1.0 | creationdate: 20 Dec 2011
Kunena default template details : Example Template | author: Kunena Team | version: 1.7.2 | creationdate: 2012-01-31
Plugins: None
13 years 1 month ago - 13 years 1 month ago #143680 by da8iwr
Now that config report idea is impressive! :D
Last edit: 13 years 1 month ago by da8iwr.
13 years 1 month ago #143684 by Matias
Go to Kunena plugins (type = kunena) and disable all the integrations you are not using (always keep kunena and joomla). That should fix your issue.
If you're using avatar integration from another component, you cannot edit the avatar from Kunena (as you're not using it).
13 years 1 month ago - 13 years 1 month ago #143687 by sozzled
*** Topics merged ***
Yes, we've answered this question before. The information you need is in this topic.
Also a good idea to use the K 2.0 Blue Eagle template instead of the one designed for K 1.7 and simplify your Kunena menu, too. ;)
And, thanks for your appreciation of how helpful the config. report tool can be. :)
Last edit: 13 years 1 month ago by sozzled.
Time to create page: 0.305 seconds
