Merged Problems with Gravatar avatar images
14 years 4 months ago #127470 by mcmoody
I just upgraded, everything is working out after some tweaks. But my avatar on my test site is gone (replaced by a placeholder?). I can't find any way to change my user avatar? Where is the button to do this? I tried changing my avatar on this Kunena support forum, thinking that would give me a guide, but I can't find it here either. Where is the avatar control? This seems like a dumb question, but I guess it's important if I can't figure it out. :P
martha
14 years 4 months ago - 14 years 4 months ago #127485 by mcmoody
I just installed CB and it solved the problem. :)
BUT I really don't need CB and I'm really kind of wanting to remove CB before this site goes live... I'm frustrated with not finding a way to change the avatar via Kunena - either on my own 2.0 installation or even this helpboard website. Why isn't there a button on the edit profile view to change the avatar?
martha
Last edit: 14 years 4 months ago by mcmoody.
14 years 3 months ago - 14 years 3 months ago #127630 by Matias
You should be able to change avatar from Kunena if all the avatar integrations are turned off (plugins tab). I cannot reproduce this in my own environment -- editing profile always displays avatar tab.
Last edit: 14 years 3 months ago by Matias.
The following user(s) said Thank You: vbsouthern
14 years 3 months ago #127985 by sozzled
Problem resolved. Problem caused by turning on Gravatar integration.
The following user(s) said Thank You: mac669, Dai-Galean
14 years 3 months ago #129331 by giorgio62
Hi everybody,
sorry for my english and I hope to be in the right place for my questions about avatars. I made a Joomla site 2.5.6 version and I installed Kunena 2.0 version inside it. Everythink works fine and I am happy with Kunena but one think, I am not capable to set Kunena in order to change avatar image for my self and for users front end site. Even if I edit my profile or user edit its own profile they can't change avatar. Thereisn't button or option displayed to change the default avatar. Can somebody help me and guide to resolve this problem. Sorry I'am beginners..... :blink:
Giorgio
14 years 3 months ago #129339 by TKtemp
Hi, check if you have enabled some Kunena Plugin to show avatar from extern application (Gravatar).
