Merged Problems with Gravatar avatar images
They are to be enabled or disabled?
Hope that developers of Kunena will change this in the future.
If you use avatar integration with Jomsocial, CB, AUP or Gravatar you can't change the Kunena avatar. But what do you need to change Kunena avatar when you use integration with something else ?
Hi xillibit,xillibit wrote: If you use avatar integration with Jomsocial, CB, AUP or Gravatar you can't change the Kunena avatar. But what do you need to change Kunena avatar when you use integration with something else ?
not all users have Gravatar account, so if you activate integration all users must have Gravatar account or no avatar.
I think that this should be option in user profile to choose from where to use avatar.
Regards
Thanks for your answers and help
Can you give us some more information about this "error", please?giorgio62 wrote: ... but if I disable the Gravatar plugin, I have an error when I do access to the main page of the Kunena forum.
