This category is only for reporting defects or problems with Kunena 1.6 test versions with Joomla 1.6. This is NOT a support forum - there is no support for test versions. Users should NOT install K 1.6 alpha or beta test versions on websites with live production data.
Sticky [Merged topic] J! 1.6 + K 1.6 - How do I restore my Kunena menu?
15 years 4 weeks ago - 15 years 4 weeks ago #92693 by sozzled
*** Topics merged ***
The solution is given in msg #26 of this topic.
Last edit: 15 years 4 weeks ago by sozzled.
The topic has been locked.
15 years 3 weeks ago #93309 by miogoogle
Hello I have a little problem with my Kunena Forum. When I click on a section or topic of the Forum module menu and header disappear - I have reviewed many times assigned the correct forms for the menus and everything is correct but can not figure out where the problem is, can you help me please?
If You look it Clik Here
Please help me :woohoo:
15 years 3 weeks ago #93311 by sozzled
15 years 1 week ago - 15 years 1 week ago #94164 by ambaqasah
Hi all
I face the same problem. This was my site:
And here is my solution:
I play with .css file under this directory:
yourjoomlainstallation/components/com_kunena/template/default/css/kunena.default-min.css
by adding the following code:
color:#FFF; padding:0px 6px 0px;
to the style: #Kunena #ktab a (NOT #Kunena #ktab a span OR #Kunena #ktab a:hover...)
and after the property: background-color:#737373;
Save the changes and the page now should be like this:
Enjoy :cheer:
Last edit: 15 years 1 week ago by ambaqasah. Reason: images doesn't appear
The following user(s) said Thank You: nur_afini, byggamore
15 years 1 week ago #94167 by sozzled
ambaqasah wrote: I play with .css file under this directory:
../components/com_kunena/template/default/css/kunena.default-min.css
Yes, that's one solution. We advise all users to not directly edit the file kunena.default-min.css because this is a minified CSS file: see Minified CSS in the Wiki.
This problem has also been fixed in K 1.6.4 which will shortly be available to the public.
15 years 1 week ago #94173 by ambaqasah
Thanks sozzled
I hope we will see the new version shortly :)
