- Thank you received: 7
This category is only for reporting defects or problems with Kunena 1.6 test versions with Joomla 1.6. This is NOT a support forum - there is no support for test versions. Users should NOT install K 1.6 alpha or beta test versions on websites with live production data.
Sticky [Merged topic] J! 1.6 + K 1.6 - How do I restore my Kunena menu?
- etkritikonspoudon
- Senior Member
15 years 7 months ago #87612
by etkritikonspoudon
Replied by etkritikonspoudon on topic Re: My Tabs are gone
Did you or anyone else by any chance delete a module title "Kunena Menu" in the Modules Manager?
It seems the installation of Kunena 1.6 adds that module which is published at the position "kunena_menu"
I unpublished this by chance, thinking it was the extra menu module I had created for the right column in my template. I then went to the forum to see the tabs missing.
I reenabled it, and voila! everything was back...
Could it be a similar case?
The following user(s) said Thank You: John Twenty
The topic has been locked.
- John Twenty
15 years 7 months ago #87623
by John Twenty
Replied by John Twenty on topic Re: My Tabs are gone
I was very hopeful, but unfortunately in my case the "Kunena Menu" was published.
I unpublished and then republished it to see if that changes anything, but with no luck
I also tried using other templates, but that too didn't help.
15 years 7 months ago - 15 years 7 months ago #87641
As you probably should know, we've collected all the K 1.6/J! 1.6 topics in one category: K 1.6 test reports - Joomla 1.6 issues . In that category (as with many categories on this forum) there is a sticky topic: J! 1.6 + K 1.6.2 - How do I restore my Kunena menu? Halfway into that topic (at around msg #19 ) is the answer you're looking for.
When you find the answer, please thank the member who posted it on the forum for your benefit and others like you.
I hope this helps.
Replied by sozzled on topic Re: My Tabs are gone
The problem is solved.John Twenty wrote: I am using Kunena 1.6.3 with Joomla 1.6.0
I hope this helps.
Last edit: 15 years 7 months ago by sozzled.
- John Twenty
15 years 7 months ago #87645
by John Twenty
I wish it was true
But it didn't fix my problem.
I also cannot get the Kunena Menu displayed, so maybe I broke something earlier
But thanx anyway
I wish it was true
But thanx anyway
15 years 7 months ago #87648
In this category, the one you posted your question to, is another sticky topic: [Merged topic] How do I restore my Kunena menu? Did you read that one, too? These kinds of questions are asked many times; that's why we create sticky topics.
- John Twenty
15 years 7 months ago #87852
by John Twenty
Ok,
I have now reinstalled my whole Joomla 1.6 and it works again now.
I think I may have broken it when trying to make some adjudtments.
Thanx anyway for your help.
Cheers
John
Cheers
John
