This category is only for reporting defects or problems with Kunena 1.6 test versions with Joomla 1.6. This is NOT a support forum - there is no support for test versions. Users should NOT install K 1.6 alpha or beta test versions on websites with live production data.
Sticky [Merged topic] J! 1.6 + K 1.6 - How do I restore my Kunena menu?
15 years 8 months ago - 15 years 5 months ago #81718 by nur_afini
I am currently using Joomla 1.6 and had installed Kunena 1.6.2. However, there is a little problem whereby the category tab (such as Recent Discussions, My Discussions, My Profile, Rules, etc) is not being displayed. I also had captured and attached the print screen of the problem. I did not faced this problem when I am using Joomla 1.5.21 with Kunena 1.5.12. Can anyone help me?
Last edit: 15 years 5 months ago by sozzled. Reason: Changed subject to improve relevance for search purposes
The topic has been locked.
15 years 8 months ago - 15 years 8 months ago #81719 by sozzled
It probably should not matter if you are running Joomla 1.6 (I can't be sure, because I haven't used J! 1.6 yet) but your problem should be fixed by using a Joomla 1.6 compatible template (most templates written for older versions of Joomla are not compatible with Joomla 1.6, by the way) and using the Create Menu button on the Kunena control panel.
Does that help?
By the way, the Recent Discussions, My Discussions, My Profile tabs don't appear if you are only a guest. ;)
15 years 8 months ago #81720 by nur_afini
This is how the Kunena page and the category tab should be displayed.
15 years 8 months ago #81721 by nur_afini
sozzled wrote: It probably should not matter if you are running Joomla 1.6 (I can't be sure, because I haven't used J! 1.6 yet) but your problem should be fixed by using a Joomla 1.6 compatible template (most templates written for older versions of Joomla are not compatible with Joomla 1.6, by the way) and using the Create Menu button on the Kunena control panel.
Does that help?
1.I am using the default template that had been provided in Joomla 1.6 installation (I assume that the template provided does not have compatibility issues :unsure: ).
2. I had tried using the Create Menu button as what you had suggested but still no luck.
3. When I login into the frontend, I still cannot see those tabs.
15 years 8 months ago #81722 by sozzled
Can you please post your K 1.6 configuration report. Thank you.
15 years 8 months ago - 15 years 8 months ago #81725 by nur_afini
When I try to click on the Report Configuration Settings button from the backend menu, I got error message like below.
Is this error indicates that the template that I was using is not compatible with Kunena?
Last edit: 15 years 8 months ago by nur_afini. Reason: Adding question.
Time to create page: 0.287 seconds
