This category is only for reporting defects or problems with Kunena 1.6 test versions with Joomla 1.6. This is NOT a support forum - there is no support for test versions. Users should NOT install K 1.6 alpha or beta test versions on websites with live production data.
Sticky [Merged topic] J! 1.6 + K 1.6 - How do I restore my Kunena menu?
15 years 6 months ago #88339 by nur_afini
I had done the steps that had been posted in reply #19. The tabs were visible now, but the buttons is not being previewed correctly though. Any suggestions on how to solve this problem.
Btw, I'm running Kunena 1.6.3 with Joomla 1.6.
Below is the screenshot.
The topic has been locked.
15 years 6 months ago #88344 by sozzled
Common J! 1.6 question. Fixed in K 1.6.4 (due for release in the next week or two - or three).
The following user(s) said Thank You: nur_afini
15 years 6 months ago #88350 by nur_afini
15 years 6 months ago - 15 years 6 months ago #89100 by tlavalle
how to i change the color of the background and the text colors? here is what i have now.
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 8M
Joomla default template details : green-day | author: Jim Beud | version: 1.6.0 | creationdate: 18 january 2011
Last edit: 15 years 6 months ago by tlavalle.
15 years 6 months ago #89101 by sozzled
This has been fixed in K 1.6.4 which is due for release shortly. We ask people to be patient and to wait for this new version to be made publicly available.
The changes can also be made if you are familiar with CSS but, as I have just mentioned, the new Blue Eagle template (included in K 1.6.4) allows you to make the changes easily by using some simple template setting changes.
  • joomlacode
  • joomlacode's Avatar
  • New Member
  • New Member
15 years 6 months ago - 15 years 6 months ago #90112 by joomlacode
I find that the Kunena menu item type in Menu manager is not normal
just like this
"kunena »kunena_entrypage_VIEW_DEFAULT_TITLE"
and other Kunena menu item type is the same
It's lower case. But according to Coding Standards of Joomla,There must be some problem.
waiting for the new version.
Good luck!
Last edit: 15 years 6 months ago by joomlacode.
Time to create page: 0.270 seconds
