Kunena 7.0.8 Released
This category is only for reporting defects or problems with Kunena 1.6 test versions with Joomla 1.6. This is NOT a support forum - there is no support for test versions. Users should NOT install K 1.6 alpha or beta test versions on websites with live production data.
Sticky [Merged topic] J! 1.6 + K 1.6 - How do I restore my Kunena menu?
15 years 7 months ago - 15 years 7 months ago #84061 by lassev
I had problems to get Kunena menu visible for my forum.
I´m using Joomla 1.6 and installed Kunena 1.6.3. for it.
Problem solved:
1. At Kunena Control Panel: create a menu if you don´t have it yet
2. At Joomla menu admin: Add a new menu item to ie. main menu
3. "menu item type": choose: Kunena -> Entry page
4. "required menu settings" -> Default menu item -> choose ie. recent topics
Worked :P
Great forum!! Thanks for it and keep up the good work!!
I still have problem to adjust menu taps width and text colour
Last edit: 15 years 7 months ago by lassev.
The following user(s) said Thank You: sozzled, jambzy, weltweites
The topic has been locked.
15 years 7 months ago - 15 years 7 months ago #84185 by Newkun
thanks mate for explaining but i posted same problem in above...plus kunena login module doesn't work well with this :( so still joomla 1.5.22 is best way for me.Does anyone know that when will joomla 1.6.1 release?Maybe it fixes these problems...
Last edit: 15 years 7 months ago by Newkun.
15 years 6 months ago #85916 by LucBrussels
I have the same problem : the Kunena menu is not showing.
The code calls function displayMenu, it checks if the module name is 'mod_mainmenu',
but the current $modules variable has one module with name 'mod_menu', so nothing is displayed.
Any advice ?
Thanks,
Luc.
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : templatetoneelbe1 | author: Luc V | version: 1.6.0 | creationdate: 28/1/2011
15 years 6 months ago - 15 years 6 months ago #86160 by Timcard30
Replied by Timcard30 on topic Kunena Menu Invisible?
I'm making a Joomla 1.6 Site that i currently host on my own Mac using MAMP.
I can't find how to place the Kunena Menu, please help me with it.
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 32M
Joomla default template details : jotempre-template_three_v1.6 | author: Tim | version: 1.2.1 | creationdate: 17.01.2011
Modules: Kunena Latest: Enabled (Version : 1.6.2) | Kunena Stats: Disabled or not installed | Kunena Login: Enabled (Version : 1.6.2)
Last edit: 15 years 6 months ago by Timcard30.
15 years 6 months ago #86162 by sozzled
Replied by sozzled on topic Re: Kunena Menu Invisible?
Please see Support for PC-hosted websites (e.g. WAMP, XAMPP)
When you describe your Kunena menu as invisible, do you mean that the background colour of the menu tabs (and the text for the menu captions) are the same colour as the site background? Or do you mean that the menu is simply not there at all?
15 years 6 months ago #86163 by Timcard30
It isn't there at all.
Time to create page: 0.315 seconds
