Kunena 7.0.8 Released
This category is only for reporting defects or problems with Kunena 1.6 test versions with Joomla 1.6. This is NOT a support forum - there is no support for test versions. Users should NOT install K 1.6 alpha or beta test versions on websites with live production data.
Sticky [Merged topic] J! 1.6 + K 1.6 - How do I restore my Kunena menu?
15 years 6 months ago #85916 by LucBrussels
I have the same problem : the Kunena menu is not showing.
The code calls function displayMenu, it checks if the module name is 'mod_mainmenu',
but the current $modules variable has one module with name 'mod_menu', so nothing is displayed.
Any advice ?
Thanks,
Luc.
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : templatetoneelbe1 | author: Luc V | version: 1.6.0 | creationdate: 28/1/2011
The topic has been locked.
15 years 6 months ago - 15 years 6 months ago #86160 by Timcard30
Replied by Timcard30 on topic Kunena Menu Invisible?
I'm making a Joomla 1.6 Site that i currently host on my own Mac using MAMP.
I can't find how to place the Kunena Menu, please help me with it.
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 32M
Joomla default template details : jotempre-template_three_v1.6 | author: Tim | version: 1.2.1 | creationdate: 17.01.2011
Modules: Kunena Latest: Enabled (Version : 1.6.2) | Kunena Stats: Disabled or not installed | Kunena Login: Enabled (Version : 1.6.2)
Last edit: 15 years 6 months ago by Timcard30.
15 years 6 months ago #86162 by sozzled
Replied by sozzled on topic Re: Kunena Menu Invisible?
Please see Support for PC-hosted websites (e.g. WAMP, XAMPP)
When you describe your Kunena menu as invisible, do you mean that the background colour of the menu tabs (and the text for the menu captions) are the same colour as the site background? Or do you mean that the menu is simply not there at all?
15 years 6 months ago #86163 by Timcard30
It isn't there at all.
15 years 6 months ago #86164 by sozzled
Thank you for clarifying that point. I have merged your topic with the topic that contains the answer. :)
15 years 6 months ago - 15 years 6 months ago #86487 by weltweites
@lassev This wortks also for me !!! Thanx man !!!
His answer to the problem :
Problem solved:
1. At Kunena Control Panel: create a menu if you don´t have it yet
2. At Joomla menu admin: Add a new menu item to ie. main menu
3. "menu item type": choose: Kunena -> Entry page
4. "required menu settings" -> Default menu item -> choose ie. recent topics
and this works !!!
Finally i can go on with preparing and making the webside
Ok this is actually what i did and everything is working acceptable :
Installed CB
Installed Kunena
Clicked make menu in kunena settings
deinstalled CB
cleared cache
Deleted the menu-structure kunena made
Made a new menu-structure as described above
Hope this helps also others .. or someone else !!
This is how it looks like now :
c.u.
here some more details .. if i click now the make menu button this error comes :
* The database row is empty.
Last edit: 15 years 6 months ago by weltweites.
Time to create page: 0.306 seconds
