i use the original template of kunina ive got joomla 1.5.25 version.
the latest kunena version and joomla dark rational template.
and i cant find whats messing with my bb code bar but it just wont show.
the url is www.carp-trips.com if someone could plz check it out i have error mesages on for now.
kindly apreciated
grtz david
See msg #1 in this topic and follow the advice given in the links.
I looked at your site and I can see why you are having problems (although I have not narrowed down the specific cause). The problem almost certain to be the fault of the Joomla site template that you've chosen (which seems to require its own customised Javascript libraries) and the Javascript libraries used on your website are interfering with Joomla's Mootools library. The "dark rational" template you are using was built between Nov 2008 and May 2009 and so, you can see, it's well and truly obsolete from a Joomla point of view! I suggest, equipped with the information I have given you, you should also read My Joomla site template makes a mess of Kunena .
after manualy changing it to 1 everything is working now.
thanks for the help anyway and maybe somone will have gotten somthing out of this one
kind regards david
I'm pleased that, in this case, discovering the cause of the problem was that easy. I hope everything works well for you with Kunena for the future.
But for some reason other users are telling me that they still can't edit their profile or add pictures to the forum in IE. Does anyone have a clue about what the problem could be? I am using a template called Braincode Grunge.
