- JuggZaPoppiN
i tried disabling practically everything.
modules, plugins, etc.
nothing fixed the problem.
i know its not the theme, or kunena template as both of those work on the test site.
Dont you think it still could be something with permissions?
Why is it that ONLY myself can edit my profile when logged into the frontend via admin?
if you are a normal user, then it wont work.
Just doesnt make any sense.
I've looked around for a bit and found some info about mootools being a possible reason for the tabs on edit profile not working. I installed the system mootools upgrade, enabled it, still no wirky. I have tried switching themes and logging out then back in, still no wirky. When i checked the source and found the mootools it showed version 1.12
using joomla 1.5.25 and kunena 1.7.1
Thanks ahead of time
- JuggZaPoppiN
Was kinda hoping that maybe you or someone else had a different theory or something else I can look at that is causing this issue.
Upon doing some checking, we noticed that we are unable to edit a user profile, upload or change an avatar by clicking on Profile tab.
What setting are we overlooking to be able to edit a profile within Kunena forums?
