- JuggZaPoppiN
Here is a copy of my configuration report.
Maybe this will help you.
This message contains confidential informationDatabase collation check: The collation of your table fields are correct
This message contains confidential informationhtaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 10MThis message contains confidential informationJoomla default template details : rt_nebulae_j16 | author: RocketTheme, LLC | version: 1.6.0 | creationdate: April 28, 2011
board_offline 0 board_ofset 0.00 enablerss 1 enablepdf 1 threads_per_page 20 messages_per_page 10 messages_per_page_search 15 showhistory 1 historylimit 6 shownew 1 jmambot 1 disemoticons 0 template aphotic-II showannouncement 1 avataroncat 1 catimagepath category_images/ showchildcaticon 1 annmodid 62 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 1 askemail 0 showemail 1 showuserstats 1 showkarma 1 useredit 1 useredittime 0 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 0 allowfavorites 1 maxsubject 50 maxsig 300 regonly 1 changename 0 pubwrite 0 floodprotection 0 mailmod 0 mailadmin 0 captcha 0 mailfull 1 allowavatar 1 allowavatarupload 1 allowavatargallery 1 avatarquality 100 avatarsize 100000 allowimageupload 0 allowimageregupload 1 imageheight 800 imagewidth 800 imagesize 100000 allowfileupload 0 allowfileregupload 1 filetypes txt,rtf,pdf,zip,tar.gz,tgz,tar.bz2 filesize 100000 showranking 1 rankimages 1 avatar_src fb fb_profile fb pm_component no userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 1 userlist_username 1 userlist_posts 1 userlist_karma 1 userlist_email 0 userlist_usertype 0 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 1 latestcategory showstats 1 showwhoisonline 1 showgenstats 1 showpopuserstats 1 popusercount 5 showpopsubjectstats 1 popsubjectcount 5 usernamechange 0 rules_infb 1 rules_cid 1 help_infb 1 help_cid 1 showspoilertag 1 showvideotag 1 showebaytag 1 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 1 ebaylanguagecode en-us fbsessiontimeout 1800 highlightcode 0 rss_type topic rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 0 rss_old_titles 1 rss_cache 900 fbdefaultpage recent default_sort asc alphauserpointsnumchars 0 sef 1 sefcats 0 sefutf8 0 showimgforguest 1 showfileforguest 1 pollnboptions 4 pollallowvoteone 1 pollenabled 1 poppollscount 5 showpoppollstats 1 polltimebtvotes 00:15:00 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 50 ordering_system mesid post_dateformat ago post_dateformat_hover datetime hide_ip 1 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png,GIF,JPEG,JPG,PNG checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 50 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty integration_access auto integration_login joomla integration_avatar kunena integration_profile kunena integration_private uddeim integration_activity auto boxghostmessage 0 userdeletetmessage 0 latestcategory_in 1 topicicons 1 onlineusers 1 debug 0 catsautosubscribed 0 showbannedreason 1 version_check 1 showthankyou 1 showpopthankyoustats 1 popthankscount 5 mod_see_deleted 0 bbcode_img_secure text listcat_show_moderators 1 lightbox 1 activity_limit 0 show_list_time 720 show_session_type 2 show_session_starttime 60 userlist_allowed 0 userlist_count_users 2 enable_threaded_layouts 0 category_subscriptions post topic_subscriptions every pubprofile 1 thankyou_max 100 email_recipient_count 0 email_recipient_privacy bcc email_visible_address captcha_post_limit 0 Third-party components: UddeIm 2.5
While it is uncommon for a Mootools Javascript library conflict to arise in J! 1.7.3, it's not impossible.
When you read msg #1 of If you are having problems with Kunena, please read this first. (as I asked you to do in msg #2 of this topic) you would have seen, in the links that are given at the end of that message, there is a tip for people who use Rockettheme templates: set Build Title Spans = No. I assume that you have already done that? Yes?
- JuggZaPoppiN
That is correct that is already done.
Do you think it could be a permissions thing?
Seeing Only myself can change their profile being I an an admin.
I did look at every setting possible and could not find anything?
Would it be easier for you to look at things if I set you a temporary admin account and PM you the details?
thanks again.
The easiest way for you to establish what is at the heart of the problem is for you to create a completely new test site, install J! 1.7.3, K 1.7.1 and nothing else. Do no add any fancy templates, or any other software. See if you can, with a non-privileged account, edit and save your Kunena profile. If you cannot do that then it calls into question whether there's something peculiar with your webhosting provider (or the way that you have configured Joomla, PHP, etc.).
Editing and saving a user profile is pretty basic stuff. The problem you have is more fundamental than giving us administrator access to your site. In cases like this, you need to find out (a) if the function works independently of whatever else you've installed before (b) figuring out what is causing this feature to not work.
- JuggZaPoppiN
I also uploaded the same theme on that site as well and the save button works on the test site.
So that would pretty much eliminate the theme causing the issue. Correct?
What you now have to do is figure out what you've done. The issue you are having could be caused by a lot of things: Common causes of Mootools (Javascript library) issues and Kunena lists some of those things. Your task is to figure out whether it's the Rockettheme template (or something added by the Rockettheme template), a module, plugin or some other extension is responsible for getting in the way of Kunena functioning the way that it should.
Now that you have a test site, you should try re-tracing your steps: add the Rockettheme template and see if, on your test site, you can still update a Kunena user profile. If you can do that then you can eliminate the Rockettheme template. And so on, add the other things you've added on your live site to your test site until you find the cause of the problem.
Useful background reading on this subject: Which came first? The template or the forum?
*** Topic moved from Support category ***
