14 years 9 months ago #114661 by onz
Hello !
i spend two hours tp find a way for fixing two problems:
i can't edit my own profile in my ownkunena for um
and i can't edit avatar too...
demosite:
www.lostcantina.com/in/index.php?option=...w=listcat&Itemid=146
user test
password test
At least;
htaccess: Missing | PHP environment: Max execution time: 120 seconds | Max execution memory: 128M | Max file upload: 64M
Joomla default template details : rt_enigma | author: RocketTheme, LLC | version: 1.0 | creationdate: October 30, 2011
Kunena default template details : Blue Eagle (default) | author: Kunena Team | version: 1.7.1 | creationdate: 2011-11-16
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Discuss 1.7.1
an idea ?
i try some tricks (titlespan off, rockbox off etc ....
it didn't work
thank you !
14 years 9 months ago #114685 by antonitus
After reading these posts about mootools, I found a plugin in my Joomla Plugin page called "System - Mootools Upgrade". This was disabled so I enabled it and now I see the profile information after refreshing the profiles page on the forum. I hope this helps people sort this out. B)
14 years 9 months ago #114686 by xillibit
I have just tried it now and it's working, so i think you have fixed the issue
14 years 9 months ago - 14 years 9 months ago #114696 by antonitus
Hi xillibit,
I am very happy to help with this brilliant forum script. It's excellent and I enjoy tinkering with it.
Sorry xillibit, I thought you were responding to my solution, probably a different problem.
Last edit: 14 years 9 months ago by antonitus.
14 years 9 months ago #114699 by sozzled
antonitus: xillibit's reply was addressed to onz. I apologise for confusing you when I merged these topics together. onz's problem has the same cause as everything contained in this topic. The solution lies in reading msg #1 of this topic and following the link in that message.
14 years 9 months ago #114700 by antonitus
Oh I see, sorry. However I solved the problem with the profile's tabs not working if this is a different issue. Apologies for the confusion although I never really solved my issue with msg #1.
Time to create page: 0.172 seconds
