My suspicion about a Javascript library conflict remains as rock-solid as it always was. I have not yet seen one case where the "Save" button (in the Kunena profile) became deactivated except through Javascript. If, in your case, it's something else then that will be the first time it's happened that way. That's why I keep suggesting that you eliminate Javascript library conflicts as a possible cause. Your test site effectively shows what happens if you don't have other things getting in the way.
- JuggZaPoppiN
How do I know what modules/extensions/plugins are javascript?
I really want to find out exactly what is causing this.
Thank you.
Of these, Kunena (and Joomla) needs 3. Those three are:
Your task is to find out what is loading these other libraries and figure out why they're being loaded, if they're necessary, and how to stop them from being loaded. One of these things is causing a problem. My guess it's the jQuery ones. There's a script error on your page:
jQuery.noConflict(go); - go is not defined.
Question for you to answer: What are you using jQuery with?
I've been researching the user profile editing problem where the menu/tabs cannot be clicked here on the support site. I'm a new user to both Joomla and Kunena so would just like to double check Im hopefully about to do the right thing to fix the problem.
I've read the two wiki articles, and from that I'm thinking that I need to upgrade my Mootools.js to 1.2 as I'm currently running 1.1.3 I think it was. Im running a Rocket Theme template at the moment too. Legacy Mode is disabled.
Have I got the right solution there for that problem? Or am I barking up the wrong tree?
Thanks for your confirmation/advice. Its much appreciated.
Jason
This message contains confidential informationhtaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 5M
Joomla default template details : rt_nebulae_j15 | author: RocketTheme, LLC | version: 1.5.2 | creationdate: November 11, 2011
Kunena default template details : Aphotic | author: snilloconator | version: 1.6.0 | creationdate: 2010-23-09
board_offline 0 board_ofset 0.00 enablerss 1 enablepdf 1 threads_per_page 20 messages_per_page 6 messages_per_page_search 15 showhistory 1 historylimit 6 shownew 1 jmambot 0 disemoticons 0 template Aphotic showannouncement 1 avataroncat 1 catimagepath category_images/ showchildcaticon 1 annmodid 62 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 1 askemail 0 showemail 0 showuserstats 1 showkarma 1 useredit 1 useredittime 0 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 1 allowfavorites 1 maxsubject 250 maxsig 1000 regonly 0 changename 0 pubwrite 0 floodprotection 0 mailmod 0 mailadmin 0 captcha 1 mailfull 1 allowavatar 1 allowavatarupload 1 allowavatargallery 1 avatarquality 100 avatarsize 2048 allowimageupload 0 allowimageregupload 1 imageheight 800 imagewidth 800 imagesize 2000 allowfileupload 0 allowfileregupload 1 filetypes txt,rtf,pdf,zip,tar.gz,tgz,tar.bz2 filesize 120 showranking 1 rankimages 1 avatar_src fb fb_profile fb pm_component no userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 1 userlist_username 1 userlist_posts 1 userlist_karma 1 userlist_email 0 userlist_usertype 1 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 1 latestcategory 0 showstats 1 showwhoisonline 1 showgenstats 1 showpopuserstats 1 popusercount 5 showpopsubjectstats 1 popsubjectcount 5 usernamechange 0 rules_infb 1 rules_cid 1 help_infb 1 help_cid 1 showspoilertag 1 showvideotag 1 showebaytag 1 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 1 ebaylanguagecode en-us fbsessiontimeout 1800 highlightcode 0 rss_type topic rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 0 rss_old_titles 1 rss_cache 900 fbdefaultpage recent default_sort asc alphauserpointsnumchars 0 sef 1 sefcats 0 sefutf8 0 showimgforguest 1 showfileforguest 1 pollnboptions 4 pollallowvoteone 1 pollenabled 1 poppollscount 5 showpoppollstats 1 polltimebtvotes 00:15:00 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 1000 ordering_system mesid post_dateformat datetime post_dateformat_hover datetime hide_ip 1 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 50 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty integration_access auto integration_login auto integration_avatar auto integration_profile auto integration_private auto integration_activity auto boxghostmessage 1 userdeletetmessage 0 latestcategory_in 1 topicicons 1 onlineusers 1 debug 0 catsautosubscribed 0 showbannedreason 0 version_check 1 showthankyou 1 showpopthankyoustats 1 popthankscount 5 mod_see_deleted 0 bbcode_img_secure text listcat_show_moderators 1 lightbox 1 activity_limit 0 show_list_time 720 show_session_type 0 show_session_starttime 0 userlist_allowed 0 userlist_count_users 1 enable_threaded_layouts 0 category_subscriptions post topic_subscriptions first pubprofile 0 thankyou_max 10 email_recipient_count 50 email_recipient_privacy bcc email_visible_address [email protected] captcha_post_limit 1
See msg #1 in this topic and follow the advice given in the links. I think the clue is your Rockettheme template.
- JuggZaPoppiN
It turned out that the Login Register module that I was using was the culprit.
It was using JQuery for google API's
I couldnt find a way to fix that so I just switched out the module and all is well now.
Again, thank you for all your help.
It is greatly appreciated
