- JuggZaPoppiN
registered users cannot edit their profiles successfully.
Whenever a user tries to add an avatar or signature and hit the save button. Nothing happens.
I however am allowed to do so when I log in as administrator.
in the kunena configuration settings I have avatars allowed, and adjusted the max size of avatars.
I am running the latest version of Joomla, and Kunena rith a RT template.
Thank you.
It's a fairly safe bet that your problems are being caused by that horrible Javascript "snow storm" effect - we've seen it before. If this is the case, you have a decision to make: "snow" vs. being able to use the forum. See msg #1 of If you are having problems with Kunena, please read this first .
- JuggZaPoppiN
I went ahead and disabled the snow feature and the issue still remains.
Only myself as admin can edit their profile.
other members who edit theirs the save button does nothing.
I don't know specifically what's the cause of your problem. In the absence of the information requested in the posting guide, and our inability to actually see the specific issues for ourselves (because you have restricted access to anyone outside your community) I was guessing. I suggest that, if you want our help, you look more closely at the posting guide printed at the top of this page and that you reconsider your decision not to share further information about your site with us. Thank you.
- JuggZaPoppiN
Hope this helps.
thank you.
I logged into your site. I tried to update the profile - pressed the save button, no response. This suggests to me that the Kunena template you're using (Snilloconator's Aphotic II - which isn't an officially supported template) doesn't work with whatever you've installed. The problem is, we don't know what you've installed.
I've asked you twice before to read the posting guide. The posting guide refers to What information should I include when I ask for help (including how to post my configuration report)? We could probably have answered your question by now if we did not have to keep asking for the information - your configuration report - to start with.
Try a different template: use the Blue Eagle template. Prove to yourself that your users can save their profile with the Blue Eagle template. If the Blue Eagle template works, then tell the author of the Aphotic II template that you're having problems with his template and whatever version of Kunena you're using. The Kunena project is not responsible for fixing problems with the Aphotic II template.
See also Which came first? The template or the forum?
