- draganstojicevic
I am using joomla 1.7 and kunena 1.7 is installed.
All I am getting is edit button with place, gender, birthday and signature, but when I click edit, page reloads with the same content.
What am I doing wrong.
There are several possibilities for what might be "wrong". First of all, I suggest that you read msg #1 of If you are having problems with Kunena, please read this first . Although it is unusual for people running J! 1.7 to experience Javascript library conflicts - and these are the main cause of people not being able to edit their user profile - it's not unheard of. The cause is often because template developers do not keep to the standard Joomla core and they implement their own Javascript libraries that clobber the Joomla core Javascript library (Mootools) - and we wish that they didn't do that!
So, the likely explanation is that you have something else installed on your site that's interfering. The link that I referred you to above should help. If it doesn't you may need to post your configuration setting so that we can see what you've got and give you better advice than what I've already done. Good luck.
I was using Community Builder, and I had installed the plug-in CB Auto Welcome 1.0.1, which caused the message "Direct Access to this location is not allowed." every time I tried to turn off the legacy mode . So, by uninstalling the Community Builder plug-in CB Auto Welcome 1.0.1 I was able to turn off the legacy mode and make the site works with no error message and the Boardcode is showing now!
I hope it can help somebody else that is facing the same issue. ;0)
did you find anything? :S
cheers,
mitja
Thanks a lot
Please see msg #1 in this topic.
