Do you have a link to your site with a test account ?
how do I get them back?
Cheers
Edit - fixed - JFinaliser settings!
By reading these articles:
Javascript and Kunena ;
Common causes of Mootools (Javascript library) issues and Kunena ;
And this thread , I've tried a lot of stuffs. Here were the tries with no success, the BoardCode kept hidden:
- Moved Mootools Upgrade for the 1st load in the system;
- Copied the mootools content from the zipped joomla 1.5.23 that has the mootools upgrade 1.2.5 to plugins/system/mtupgrade;
- Copied the mootools content from the zipped joomla 1.5.23 that has the mootools upgrade 1.2.5 to media/system/js;
- Tried into another templates, so the issue isn't in the template;
- Removed JCE component;
- renamed all mootools files into media/system/js, to not find the files;
- Removed JNews component. After removing it, the BoardCode appeared, but after refreshing the page, dissapeared again and never more see it again;
- Disabled all modules and nothing happened, the BoardCode kept hidden;
It is driving me crazy! I'll keep trying.
I wonder:
1. When I check my code with firebug, the newtopic page doesn't build this boardcode into the code.
Isn't it possible to Kunena devs, change how it works, once a lot of people are facing the same issue?
2. Once it isn't an issue theme, is there any possibility the mootools.js be called twice into some page from Kunena? If so, which page I would look into? Which php files builds the new topic?
3. I have noticed that by activing mootool12 it shows the board code, but causes other errors. Do I need to have both activated Mootools12 and Mootools Upgrade?
Why you replaced Mootools Upgrade plugin from the latest Joomla with the older version? Just install latest .25 version and you should be fine...
You're looking this in wrong way. I would start from looking at the source code of the page, to see what JavaScript files get loaded and from where. Also enabling debug mode reveals usually some information what may be broken (use FireFox for that -- IE7/8 is buggy).
But please, do not put the same information into more than one place. I get confused if people post into more than one topic and are discussing from a singe issue in both/all.
uninstall-reinstall, nothing helps.
Any ideas?
