14 years 9 months ago #116008 by CheechDogg
Wow, that is a MooTools issue? I don't think I have come across it ever. I have though come across the bb code issue. Thanks once again sozzled!
[img
Find me on Facebook.
14 years 9 months ago #116020 by Wistiti76
sozzled wrote: Wistiti76: Please see msg #1 in this topic. The answer is there.
You solved it, thanks a lot !
14 years 9 months ago - 14 years 9 months ago #116162 by rinuccio sp
Hi, i've installed now K1.7.1 with Importer 1.7.1
Great Work :D but toolbar profile tabs etc not work...
My template is magazine_plazza
I've enabled mootools upgrade plugin but no work :(
This my conf report:
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 256M | Max file upload: 64M
Joomla default template details : magazine_plazza | author: TemplatePlazza.com | version: 1.0 | creationdate: June 2008
Kunena default template details : Blue Eagle (default) | author: Kunena Team | version: 1.7.1 | creationdate: 2011-11-16
Last edit: 14 years 9 months ago by sozzled. Reason: Reveal Kunena configuration report in message
14 years 9 months ago #116163 by sozzled
The problem that you have with the TemplatePlazza template - let me add that TemplatePlazza templates are a nightmare to diagnose and debug because they don't work very well with J! 1.5 - is not easily solved by simply enabling the Mootools Upgrade plugin. Many third-party Joomla templates designed before June 2009 are, quite bluntly, completely unworkable in today's environment and (in my opinion) most of TemplatePlazza templates fall into that category.
The problem you have is the same kind of problem that many people have with conflicting Javascript libraries introduced with the Joomla extenssions that they've chosen to use. The problem could best be summarised by My Joomla template is making a mess of Kunena . In this case, the answers are still the same: see msg #1 of this topic.
14 years 9 months ago - 14 years 9 months ago #116174 by rinuccio sp
With other template (joomla) toolbar work -.-"
How to solve?
templateplazza is offline for weeks :(
EDIT:
I've read first post.
My source page load two mootools
1° in plugins/system/mtupgrade/mootools.js version 1.2.4
2° in templates/magazine_plazza/scripts/js/mootools.js version 1.11 O_O
How to disable this? :) :) :)
Last edit: 14 years 9 months ago by rinuccio sp.
14 years 9 months ago #116179 by sozzled
TemplatePlazza is non-responsive. We understand. However, this is not the TemplatePlazza support forum, either.
You need to get rid of the templates/magazine_plazza/scripts/js/mootools.js (version 1.11). Rename it to something else.
Time to create page: 0.166 seconds
