14 years 9 months ago #116663 by sozzled
freetayyeb wrote: edit button in kunena 1.6.4 profile page disappeared,
what is the problem?
See msg #1 in this topic.
14 years 9 months ago - 14 years 9 months ago #116688 by fstltna
I updated to the latest version and tried reinstalling but it did not fix this. For some reason my editor buttons are not showing up, as you can see in the attached file there is just a little bit of white instead of the whole button bar. Can someone point me in the right direction?
Legacy mode: Enabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 32M
Joomla default template details : game_crusade | author: Shape5.com | version: 1.0 | creationdate: December 2009
Kunena default template details : Adrine Dark - Kunena 1.6 Template | author: www.TemplateKunena.com | version: 1.6.4 | creationdate: 2011-06-01
Third-party components: Jomsocial 2.2.4 | UddeIm
Plugins: System - Mootools Upgrade: Enabled | System - Mootools12: Disabled | Kunena Search 1.7.0 | Kunena Discuss 1.7.0
Modules: Kunena Latest 1.7.0 | Kunena Stats 1.7.0 | Kunena Login 1.6.2
Last edit: 14 years 9 months ago by fstltna. Reason: Added report
14 years 9 months ago #116689 by CheechDogg
Hello fstltna. Can you please post your forums configuration report so that the Mods or Devs can see what is going on? Without this report we can only speculate as to what is going on?
From the image you have provided it does not look like you are using the Blue Eagle (default) and it could be that something in that template is causing the problem.
[img
Find me on Facebook.
14 years 9 months ago #116690 by CheechDogg
Ok good , from what I can see you are using a 3rd party template and you have legacy mode turned on.
Please turn off legacy mode and see if that fixes the problem. If it does not, please use the Blue Eagle (default) template and check to see if your editor buttons are showing up. If they are, you will need to contact someone from www.TemplateKunena.com and get some information about this template.
[img
14 years 9 months ago #116693 by fstltna
This template has been working for quite a while without changes. I just updated JCE and I think it broke the mootools library support. I dont think it is the template because that hasnt changed. Likewise I have not changed legacy mode...
14 years 9 months ago #116694 by CheechDogg
Ok then disable jce for the moment to see if that brings back your editor buttons. If it does then you know jce is the culprit.
I personally do not use JCE anymore because of this very issue. It seems to conflict with other scripts on my site.
[img
Time to create page: 0.172 seconds
