14 years 8 months ago - 14 years 8 months ago #117689 by Jiminimonka
What trouble are you having loading avatars, what happens? Mootools is part of Joomla now.
EDIT: You should update to Kunena 1.7.2 by the way.
Please read the FAQ.
Only one question per topic.
Last edit: 14 years 8 months ago by Jiminimonka.
14 years 8 months ago - 14 years 8 months ago #117695 by Melinda
Hey there,
the problem Im having is I am unable to upload an avatar, or change/configure profile data.
This screen grab is from my profile page. All the stuff that should be configurable is all completely unclickable and uneditable. You cant upload photos or add location data.
Jim, thanks for the advice about updating to 1.7.2 - might it resolve this avatar issue?
Last edit: 14 years 8 months ago by Melinda.
14 years 8 months ago - 14 years 8 months ago #117697 by Jiminimonka
The problem is that you cannot see the Edit button isn't it.
Go into the Gantry Template setting Advanced and turn off Build Title Spans - problem fixed.
Still you need to update to Kunena 1.7.2. It works better and fixes many things.
Also, the Example Template is really just a blank example for template makers to use, you should use Blue Eagle for now, until K2.0 comes out.
The following user(s) said Thank You: Melinda
14 years 8 months ago #117723 by Melinda
Hi Jim, thanks for taking the time to advise me- I will change the Kunena templates over.
And thank you so much for telling me about 'Build Title Spans!'
Solved my proved completely!
Easy when you know how isnt it?! Thanks so much!
Mel x.
14 years 8 months ago #117747 by Jiminimonka
Thanks. It happened to me, that is how I know :silly:
The following user(s) said Thank You: CheechDogg, Melinda
14 years 8 months ago - 14 years 8 months ago #117758 by sozzled
Melinda: do not use the Example template (it is actually not a working template); use the Blue Eagle template. K 1.6.4 is not supported.
Build Title Spans = Off is the solution (... yes, it's a Mootools conflict, yes, the answer is contained in the links in msg #1 of this topic ... and yes, this is a known issue with Cloudbase.net templates!)
J! 1.6.4 is not supported by Joomla.
Last edit: 14 years 8 months ago by sozzled.
Time to create page: 0.161 seconds
