14 years 9 months ago - 14 years 9 months ago #117838 by krayzie.kry
Replied by krayzie.kry on topic Problems with mootools
Hi ive installed Kunena 1.6 on www.loredanalatis.ro/forum and i have some problems. Ive read the forum here resolving the cannot change profile problem with mootools upgrade, i have mootools upgrade but same problem exits. One more question, when i enter the sucategory the top menu dissapears, i cant figure why ... thank you for the help
Because of the mootools i cannot put seo links to work either
htaccess: Exists | PHP environment: Max execution time: 90 seconds | Max execution memory: 256M | Max file upload: 100M
Joomla default template details : real_tdc | author: YOOtheme | version: 1.5.0 | creationdate: March 2010
Last edit: 14 years 9 months ago by krayzie.kry.
14 years 9 months ago #117839 by sozzled
krayzie.kry: K 1.6.5 is not supported. If you want help from this forum, please upgrade to K 1.7.2.
Please read msg #1 in this topic for the answer to your Mootools problems.
14 years 9 months ago - 14 years 9 months ago #117897 by Lili
Replied by Lili on topic WYSIWYG bar / Boardcode
I've been running my forum no problem for the past 8 months. Yesterday I had to clear some stuff on my site and I think that I deleted something... I can't see the WYSIWYG bar and the emoticon are not working...
I update my forum to 1.7 and it didn't fix it :( I am desperate can you help me ?
Tell me what I can do please :unsure:
Last edit: 14 years 9 months ago by Lili.
14 years 9 months ago #117900 by sozzled
Lili: you probably lost the BBcode toolbar because of a Javascript library conflict created by another Joomla extension that is not compatible with Joomla. There are many Joomla extensions that cause these kinds of problems.
Please read msg #1 in this topic for the answers.
The following user(s) said Thank You: Lili
14 years 9 months ago - 14 years 9 months ago #117921 by Lili
The problem was there before I upgrade. Checked mototools and it is ok... I have more than 8000 members and the forum is really getting big...
My site is www.onmagasine.ca
Here are the infos
[/quote]
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : magasine29 | author: | version: 1.0 | creationdate: 2012-02-05
Third-party components: CommunityBuilder 1.4 | UddeIm 2.5
Modules: Kunena Latest 1.6.4
Really really don't know...
14 years 9 months ago #117960 by sozzled
Lili: Please read What information should I include when I ask for help (including how to post my configuration report)? There is some vital information missing from the report that you posted. Please post your unedited configuration report and then I may have an opportunity to learn more.
The most important part of the problem that we're dealing with, Lili, is that you are running some version of J! 1.5 (I don't know what specific version you are using, or whether that version meets the requirements for K 1.7.2, because you deleted that information from the configuration report) because you have legacy mode enabled. Please read legacy mode in the Wiki.
It would be of assistance if we could actually see the problem that you say you are having. Do you have a test account that we could use? You can post the details of the test account here using the
Time to create page: 0.200 seconds
