14 years 8 months ago #118078 by krayzie.kry
Hi i have updated kunena from 1.6 to 1.7 the debug says deprecated 1.12 mootools but i have plugin mootools upgrade activated. Please help me i cant seem to get to upgrader mootools for kunena to work. The site i talk about is www.loredanalatis.ro/forum . The top menu in categories dissapear and I cannot use friendly url in kunena
htaccess: Exists | PHP environment: Max execution time: 90 seconds | Max execution memory: 256M | Max file upload: 100M
Joomla default template details : real_tdc | author: YOOtheme | version: 1.5.0 | creationdate: March 2010
14 years 8 months ago #118096 by sozzled
krayzie.kry: The answer to your question is in msg #1 of this topic. You are using another Joomla extension (I think that it may be JCE MediaBox) that loads a customised Javascript library which overrides Joomla! You need to identify what that extension is and remove it.
Your Kunena menu disappears because you have two menu items (both of them with the alias "forum") that point to two different things. Remove the item with the target "index.php?option=com_kunena&view=listcat&catid=0". Please also read Search Engine Optimisation (SEO) in the Wiki.
Your website loads at least 12 Javascript libraries; Kunena needs 3 of them. Your task is to figure out why you need the other 9 and which one(s) is/are conflicting with Mootools 1.2.4.
14 years 8 months ago #118146 by mbires
I have searched the forum and can not find a simple answer to my question....
How do my members change their avatar, location, gender and birthdate. When the click on Profile, it shows them these options with the words "Unknown" in grey next to each item. There is no edit button to press.
Please help
14 years 8 months ago #118148 by xpatman
Replied by xpatman on topic MooTools and IE
Hi
I know I will get told that this subject has been covered before but
I have just upgraded to 1.7.2 and for some reason on IE it has the 'MooTools Doomready event"
error
BUT its ONLY in IE, Firefox and Chrome are OK
Any ideas as I have not found an answer on line
Legacy mode: Disabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Disabled | FTP layer: Enabled |
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 2M
Joomla default template details : youwinner | author: Youjoomla LLC | version: 1.0 | creationdate: 12-22-2010
Third-party components: CommunityBuilder 1.7.1 | UddeIm 2.5
Modules: Kunena Latest 1.7.2 | Kunena Stats 1.7.2 | Kunena Search 1.7.2
14 years 8 months ago #118154 by sozzled
Replied by sozzled on topic Re: MooTools and IE
xpatman wrote: I know I will get told that this subject has been covered before ...
I'm sorry the one who is the bearer of such news, however, you will find the answers to your question in msg #1 of this topic. You are loading K2 and jQuery that could be a reason why the DOMready event is not firing. Just as likely is that you are using a template designed for an older version of a Kunena template may not have been tested with IE9. You should eliminate that possibility by using the Blue Eagle template (as a test, if for no other reason).
The problem may only affect some users of [certain versions of] Internet Explorer when they view certain pages of your site but they did not affect me - using IE9 - when I looked at your site.
14 years 8 months ago #118155 by sozzled
Replied by sozzled on topic Re: There is no edit button
G'day, mbires, and welcome to Kunena.
mbires wrote: There is no edit button to press.
There's the key word and, if you searched the forum you will find the answer in msg #1 of this topic.
Time to create page: 0.197 seconds
